Aller au contenu principal
Lenovo Y50-70 Touch Motherboard Replacement
Tanner Tomlinson
Tanner Tomlinson et 3 autres contributeurs
Dernière mise à jour le June 1, 2022
10 - 20 minutes
Modérée
In this guide, the reader will go through the necessary instructions needed to replace a non-functioning motherboard in the Lenovo Y50-70 Touch Laptop. This specific repair does not require any previous knowledge about computers and can be completed by a beginner using only a single Phillips #1 screwdriver and a small plastic prying tool.
When performing this repair, ensure you are in a static free environment so as not to provide an electrical shock to the computer and possibly further damage the device.
Ce dont vous avez besoin
Outils
  1. Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: étape 1, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: étape 1, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
    • Grab and pull off the back.
  2. Lenovo Y50-70 Touch Motherboard Replacement: étape 2, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 2, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 2, image 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the battery.
    • Grab the battery cable and gently pull it free from the cable connector.
    • Remove the battery.
  3. Lenovo Y50-70 Touch Motherboard Replacement: étape 3, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 3, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 3, image 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the hard drive.
    • Grab the marked cable attached to the hard drive, and gently pull to unplug.
    • Remove the hard drive from the laptop.
  4. Lenovo Y50-70 Touch Motherboard Replacement: étape 4, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 4, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 4, image 3 de 3
    • Grab marked cables and pull them out from their plug-in.
  5. Lenovo Y50-70 Touch Motherboard Replacement: étape 5, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 5, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 5, image 3 de 3
    • Grab the top set of marked cables and pull up to remove them.
    • Grab the lower marked cable and pull it out from their plug.
  6. Lenovo Y50-70 Touch Motherboard Replacement: étape 6, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 6, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 6, image 3 de 3
    • Grab marked cables and pull up to unplug.
  7. Lenovo Y50-70 Touch Motherboard Replacement: étape 7, image 1 de 2 Lenovo Y50-70 Touch Motherboard Replacement: étape 7, image 2 de 2
    • Grab marked cables and pull out to unplug.
  8. Lenovo Y50-70 Touch Motherboard Replacement: étape 8, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 8, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 8, image 3 de 3
    • Grab the black tab on top of the cable and pull up to unplug.
  9. Lenovo Y50-70 Touch Motherboard Replacement: étape 9, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 9, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 9, image 3 de 3
    • Lift the black tab on top of the marked cable.
    • Grab the colored tab on the cable and pull to remove the cable.
  10. Lenovo Y50-70 Touch Motherboard Replacement: étape 10, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 10, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 10, image 3 de 3
  11. Lenovo Y50-70 Touch Motherboard Replacement: étape 11, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 11, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 11, image 3 de 3
  12. Lenovo Y50-70 Touch Motherboard Replacement: étape 12, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 12, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 12, image 3 de 3
    • Lift the black tab on top of the marked cables.
    • Grab the colored tab on the cables and pull to remove the cables.
  13. Lenovo Y50-70 Touch Motherboard Replacement: étape 13, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 13, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 13, image 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the six 7 mm screws from the heat sink.
    • Grab and lift the heatsink off the motherboard.
  14. Lenovo Y50-70 Touch Motherboard Replacement: étape 14, image 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 14, image 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: étape 14, image 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws marked with red circles on the motherboard.
    • Grab and lift the motherboard up and out from the laptop.
3 autres ont terminé cette réparation.
Tanner Tomlinson
Membre depuis le 04/12/22
283 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 6-6, Beck Spring 2022 Membre de l'équipe IUPUI, Team 6-6, Beck Spring 2022
IUPUI-BECK-S22S6G6
4 membres
3 tutoriels rédigés
Un commentaire
Attempting this tomorrow soldiers, wish me luck o7
j.c.glaab - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 16
Total : 1,362
