Aller au contenu principal
Lenovo Yoga 3 11 Trackpad Replacement
Slade Fernandes
Slade Fernandes et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
30 - 40 minutes
Modérée
Nécessite plus d'images
Photos d’action
Is your laptop's trackpad not reacting when you use it? Then you will probably need to replace it and this guide will help you accomplish the task!
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Lenovo Yoga 3 11 Trackpad Replacement, Lower Case: étape 1, image 1 de 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Trackpad Replacement, Battery: étape 2, image 1 de 3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: étape 2, image 2 de 3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: étape 2, image 3 de 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Trackpad Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Trackpad Replacement: étape 4, image 1 de 2 Lenovo Yoga 3 11 Trackpad Replacement: étape 4, image 2 de 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Trackpad Replacement: étape 5, image 1 de 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Trackpad Replacement, Trackpad: étape 6, image 1 de 1
    • Remove the four 2 mm Phillips #0 securing the trackpad.
  7. Lenovo Yoga 3 11 Trackpad Replacement: étape 7, image 1 de 1
    • Use the tweezers to partially remove the tape.
  8. Lenovo Yoga 3 11 Trackpad Replacement: étape 8, image 1 de 2 Lenovo Yoga 3 11 Trackpad Replacement: étape 8, image 2 de 2
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
  9. Lenovo Yoga 3 11 Trackpad Replacement: étape 9, image 1 de 2 Lenovo Yoga 3 11 Trackpad Replacement: étape 9, image 2 de 2
    • Slightly push down with your thumb to pop out the trackpad.
    • The laptop must be slightly open in order for the trackpad to pop out.
Slade Fernandes
Membre depuis le 08/27/15
532 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 2-3, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 membres
11 tutoriels rédigés
Un commentaire
Very brief, great illustrations. Now, I need to try it.
M T Martinez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 25
Total : 2,935
