Marshall Emberton Main Speaker Replacement
Introduction
Passez à l'étape 1The Marshall Emberton has two main speakers which are on the front and backside of the speaker. These speakers produce quality bass and sound. Like any other speaker, the audio eventually loses it’s power.
With the help of this guide, you will be able to replace both main speakers. Replacing these speakers requires a TR-9 screwdriver.
Ce dont vous avez besoin
Remove the rubber casing from the speaker by peeling it off using your nails.
Now pop the speaker out and remove the entire piece.
Don't you need to open up the motherboard in order to remove the speaker?? The speaker needs to attach to it.
Where i can Pay the replace speaker ?
Now you must disconnect two wire connectors, by firmly tugging on the wires.
The new speakers can now be connected and put back together.
Hi Where can I buy the replacement speaker please.
pierre@woodteq.co.za
Did you find any?
I need to replace my speaker which one do I get
this suggestion is not for any of the steps but be sure to put in a suggested time, I would also suggest changing the difficulty from moderate to easy since this seems pretty easy compared to the other guides
Joseph Hernandez - Réponse
