Aller au contenu principal
Marshall Emberton Main Speaker Replacement
Asia Baldwin
Asia Baldwin et 8 autres contributeurs
Dernière mise à jour le January 17, 2025
20 minutes
Modérée
Nécessite plus d'images
The Marshall Emberton has two main speakers which are on the front and backside of the speaker. These speakers produce quality bass and sound. Like any other speaker, the audio eventually loses it’s power.
With the help of this guide, you will be able to replace both main speakers. Replacing these speakers requires a TR-9 screwdriver.
Ce dont vous avez besoin
  1. Marshall Emberton Main Speaker Replacement, Main Speaker: étape 1, image 1 de 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
    this suggestion is not for any of the steps but be sure to put in a suggested time, I would also suggest changing the difficulty from moderate to easy since this seems pretty easy compared to the other guides
    Joseph Hernandez - Réponse
  2. Marshall Emberton Main Speaker Replacement: étape 2, image 1 de 1
    • Pry the front of the speaker that says "Marshall" in order to get inside the speaker.
  3. Marshall Emberton Main Speaker Replacement: étape 3, image 1 de 1
    • Remove the eight 1.2 cm screws using a TR9 screwdriver.
  4. Marshall Emberton Main Speaker Replacement: étape 4, image 1 de 1
    • Now pop the speaker out and remove the entire piece.
    Don't you need to open up the motherboard in order to remove the speaker?? The speaker needs to attach to it.
    Frederick Jimenez - Réponse
    A few more pictures of different angles or how it looks like by itself would be helpful.
    Alejandro - Réponse
    Where i can Pay the replace speaker ?
    Antoineshk - Réponse
  5. Marshall Emberton Main Speaker Replacement: étape 5, image 1 de 1
    • Now you must disconnect two wire connectors, by firmly tugging on the wires.
    • The new speakers can now be connected and put back together.
    Hi Where can I buy the replacement speaker please.
    pierre@woodteq.co.za
    Pierre Fourie - Réponse
    Did you find any?
    Martin Earle -
    I need to replace my speaker which one do I get
    Richard Skinner - Réponse
Asia Baldwin
Membre depuis le 09/26/22
724 Réputation
5 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 membres
6 tutoriels rédigés
1 commentaire de tutoriel
Hi! Where from can I by the speakers? pls help
Cristian MUNTEANU - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 72
Total : 3,650
