Aller au contenu principal
Nest x Yale Lock Keypad Replacement
Christopher Gonzalez
Christopher Gonzalez et 3 autres contributeurs
Dernière mise à jour le December 27, 2022
20 minutes
Modérée
If your Nest x Yale lock is related to any of the issues on the unresponsive section of your troubleshooting page, you may need to replace the touchpad. Use this guide to replace the keypad properly.
The touchpad is located inside the keypad. This touchpad is responsible for being able to input your code to unlock the door lock.
Before beginning this process, be sure that the device is off and not plugged into the lock.
Ce dont vous avez besoin
Outils
  1. Nest x Yale Lock Keypad Replacement, Keypad: étape 1, image 1 de 1
    • Unscrew all available screws that you can see from the back.
    • The screws are 0.25 inches phillips screws.
    • Make sure to not lose any of the screws, and keep track of them.
    I would suggest removing the word 'you' and start with 'Unscrew'
    Hazem Shekfa - Réponse
  2. Nest x Yale Lock Keypad Replacement: étape 2, image 1 de 1
    • Once you have unscrewed all the screws carefully remove the metal covering.
    • Make sure that the wire safely goes through the hole.
    No need to say 'also' since it is a note
  3. Nest x Yale Lock Keypad Replacement: étape 3, image 1 de 1
    • Then once again unscrew the two screws that you see.
    • The screws have a height of 0.2 inches phillips screws.
    Provide an amount of how many screws needed to be unscrewed in this step
  4. Nest x Yale Lock Keypad Replacement: étape 4, image 1 de 2 Nest x Yale Lock Keypad Replacement: étape 4, image 2 de 2
    • Once all screws are unscrewed proceed to tap the screen out of the metal casing.
    The two photos in this step look very identical
Membre depuis le 09/26/22
313 Réputation
3 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 membres
5 tutoriels rédigés
1 commentaire de tutoriel
Where do you order the touchscreen from?
Mike Turrell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 366
