Introduction
Use this guide to remove the white plastic outer case protecting the Wii's innards. Removing the outer case requires a Tri-wing screwdriver.
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
24 autre(s) ont terminé cette réparation.
