Aller au contenu principal
Razer Barracuda X Motherboard Replacement
Josiah Cassidy
Josiah Cassidy et 6 autres contributeurs
Dernière mise à jour le January 8, 2025
30 - 40 minutes
Modérée
Nécessite plus d'images
Étapes manquantes
Meilleure introduction
Ce dont vous avez besoin
Outils
  1. Razer Barracuda X Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Razer Barracuda X Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Remove the cushion by pulling it off from the edge and out from the grooves, Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Motherboard Replacement: étape 2, image 1 de 3 Razer Barracuda X Motherboard Replacement: étape 2, image 2 de 3 Razer Barracuda X Motherboard Replacement: étape 2, image 3 de 3
    • Using a Phillips #0 screwdriver to unscrew the four screws that attach the two pieces of the right speaker together.
    • Gently lift the plastic plate away from the housing, with care not to damage the connected wire.
  3. Razer Barracuda X Motherboard Replacement: étape 3, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the single screw attaching the volume spinner to the motherboard.
    • Remove the spinner.
  4. Razer Barracuda X Motherboard Replacement: étape 4, image 1 de 1
    • Remove the Phillips #0 screws securing the I/O board from the bottom shell of the right speaker.
    what size and how many pins have that ribbon cable
    Melz - Réponse
  5. Razer Barracuda X Motherboard Replacement: étape 5, image 1 de 2 Razer Barracuda X Motherboard Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • To fully remove the I/O board from the right speaker, use tweezers to unplug the ribbon cable attaching the I/O board to the main motherboard.
  6. Razer Barracuda X Motherboard Replacement: étape 6, image 1 de 1
    • Using the same Philips #0 screwdriver, remove the four screws attaching the motherboard to the plastic housing. Once those screws are removed, remove the main motherboard and replace it.
  7. Razer Barracuda X Motherboard Replacement: étape 7, image 1 de 3 Razer Barracuda X Motherboard Replacement: étape 7, image 2 de 3 Razer Barracuda X Motherboard Replacement: étape 7, image 3 de 3
    • Desolder all of the remaining motherboard connections.
    • Do not hold the iron by the barrel as depicted in the images.
    • Remove the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
3 autres ont terminé cette réparation.
Josiah Cassidy
Membre depuis le 10/26/22
244 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Petersen Fall 2022 Membre de l'équipe UMass Dartmouth, Team 2-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G3
4 membres
10 tutoriels rédigés
4 commentaires de tutoriel
Now if I could just find somewhere to buy the I/O board. My volume slider is crackling and sometimes one cup is louder than the other.
Michael Nugent - Réponse
You ever find a replacement?
Gaelan Garrett -
i found that submerging the volume dial in Isopropyl alcohol and moving the volume up and down cleans the wheel internal contacts and it no longer has this issue.
Mexicanskynet -
@michaelnugent My volume wheel just broke too! Must be a weak point in the design.
Michael Shu - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 38
30 derniers jours : 174
Total : 4,322
