Aller au contenu principal
Razer Blade 15" (2020) SSD Replacement
Clay Eickemeyer
Clay Eickemeyer
Dernière mise à jour le October 6, 2023
15 - 30 minutes
Modérée
Tutoriel vedette
Use this guide to replace or upgrade the PCIe M.2 2280 SSD in your Razer Blade 15" (2020) laptop.
Note: This laptop doesn't support SATA M.2 SSDs.
Before you perform this repair, back up your existing SSD if possible. If you're replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD. There are many tools to do this, but this article is a good place to start if you're unfamiliar with the process.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Razer Blade 15" (2020) SSD Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 2 Razer Blade 15" (2020) SSD Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) SSD Replacement, Unfasten the back cover: étape 2, image 1 de 1
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: étape 3, image 1 de 3 Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: étape 3, image 2 de 3 Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: étape 3, image 3 de 3
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) SSD Replacement, Remove the back cover: étape 4, image 1 de 3 Razer Blade 15" (2020) SSD Replacement, Remove the back cover: étape 4, image 2 de 3 Razer Blade 15" (2020) SSD Replacement, Remove the back cover: étape 4, image 3 de 3
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) SSD Replacement, Soften the battery cable tape adhesive: étape 5, image 1 de 2 Razer Blade 15" (2020) SSD Replacement, Soften the battery cable tape adhesive: étape 5, image 2 de 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: étape 6, image 1 de 3 Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: étape 6, image 2 de 3 Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) SSD Replacement, Disconnect the battery: étape 7, image 1 de 2 Razer Blade 15" (2020) SSD Replacement, Disconnect the battery: étape 7, image 2 de 2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: étape 8, image 1 de 3 Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: étape 8, image 2 de 3 Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: étape 8, image 3 de 3
    • Use a Phillips screwdriver to remove the 3.1 mm screw securing the SSD.
    • The SSD will pop up slightly.
  9. Razer Blade 15" (2020) SSD Replacement, Remove the SSD: étape 9, image 1 de 3 Razer Blade 15" (2020) SSD Replacement, Remove the SSD: étape 9, image 2 de 3 Razer Blade 15" (2020) SSD Replacement, Remove the SSD: étape 9, image 3 de 3
    • Pull the SSD straight out of its socket and remove it.
    • During reassembly, insert the SSD at a slight downward angle before lowering it flat to the frame and securing it with its screw.
Clay Eickemeyer
Membre depuis le 09/19/22
82 335 Réputation
455 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
9 membres
11 502 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 623
