Aller au contenu principal
Removing the HP Elitebook 6930p Keyboard
Richdave
Richdave et un autre contributeur
Dernière mise à jour le June 23, 2022
10 minutes
Modérée
Tutoriel réalisé par la communauté
This guide will show you how to remove the keyboard
Ce dont vous avez besoin
Outils
  1. Removing the HP Elitebook 6930p Keyboard, Battery Removal: étape 1, image 1 de 3 Removing the HP Elitebook 6930p Keyboard, Battery Removal: étape 1, image 2 de 3 Removing the HP Elitebook 6930p Keyboard, Battery Removal: étape 1, image 3 de 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Keyboard, Keyboard: étape 2, image 1 de 3 Removing the HP Elitebook 6930p Keyboard, Keyboard: étape 2, image 2 de 3 Removing the HP Elitebook 6930p Keyboard, Keyboard: étape 2, image 3 de 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Keyboard: étape 3, image 1 de 3 Removing the HP Elitebook 6930p Keyboard: étape 3, image 2 de 3 Removing the HP Elitebook 6930p Keyboard: étape 3, image 3 de 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
    After loosening the four moveable tabs at the screen end you simply pull slightly to the right to loosen the left side and then up to loose the five tabs in the lower end, then flip keyboard over so keys face the screen.
    e5frog - Réponse
  4. Removing the HP Elitebook 6930p Keyboard: étape 4, image 1 de 3 Removing the HP Elitebook 6930p Keyboard: étape 4, image 2 de 3 Removing the HP Elitebook 6930p Keyboard: étape 4, image 3 de 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
    There is no need at all to loosen any ribbon cables, after flipping keyboard so it faces keys against screen you can simply remove the RAM. Don't fiddle with the ribbon cables.
    e5frog - Réponse
    Unless, of course, that your actually replacing the keyboard! In which case, remember to keep that rubber pointing device for replacing the one that you’ll probably eventually lose.
    Dennis - Réponse
9 autres ont terminé cette réparation.
Richdave
Membre depuis le 04/09/10
32 413 Réputation
30 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
327 membres
1 672 tutoriels rédigés
2 commentaires de tutoriel
Look easy to remove !! I have a hp elitebook 6930p it need a new keyboard but it hard for me to find one for my elitebook 6930p online they look the same but none of them have the part number i need ! Could i use any hp elitebook 6930p replacement keyboard or were can i find the right keyboard number on the elitebook 6930 i just might be looking at the wrote number ! Need help !!
Daisy - Réponse
CHICONY
MP-06803U46930 MP-06803US6442
DARFON
9J.N8282.K01 NSK-H4K01
HP COMPAQ
483010-001 90.4V907.S01 9J.N8282.K01 BAHHH3AM2WS0E7
MP-06803U46930 MP-06803US6442 NSK-H4K01 V070530CS1
any of these should work
Keegan -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 30
Total : 10,743
