Aller au contenu principal
Remplacement de la vitre du Nextbook 8
Dylan Wiese
Dylan Wiese et 3 autres contributeurs
Dernière mise à jour le January 20, 2025
Aucune estimation
Modérée
Détails manquants
La vitre de votre Nextbook 8 est-elle cassée? Utilisez ce guide pour remplacer le verre sur l’écran avant.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Remplacement de la vitre du Nextbook 8, Batterie: étape 1, image 1 de 2 Remplacement de la vitre du Nextbook 8, Batterie: étape 1, image 2 de 2
    • Utilisez l’outil d’ouverture en plastique pour retirer le capot arrière. Faites glisser délicatement l'outil entre la vitre avant et le capot arrière.
    • Faites glisser l'outil le long du bord pour dégager le capot arrière.
    • Il est utile d’avoir un outil supplémentaire pour coller l’espace et maintenir le capot arrière séparé du verre lorsque vous faites glisser l’autre outil.
    Did this tablet have a speaker soldered onto the mainboard? I'm working on a Nextbook 8 NX785QC8G as well, and the first thing I saw was that there's a speaker held together with three screws and a bit of adhesive to the back cover and its cables are soldered onto the motherboard. I don't believe that I ruined them, but they do look a little loose.
    Eliza Salazar - Réponse
    The first Nextbook 8 model NX785QC8G tablet I bought, was from Walmart sometime mid summer 2014 AND it was running Jelly Bean. Battery lasted maybe 5 1/2 months; didn't realize tablet had 1 year warranty if I registered tablet with copy of receipt and have it fixed.
    So, bought another Nextbook NX785QC8Gu several months later; this one came out running KitKat. I registered online and copied my receipt, which was uploaded to them. Still have had several problems with battery...ie.turning off before completely discharged, not charging in a reliable steady manner,and more. The Li-ion battery(what I thought it was), being 4,000 mAh, should be more than enough to last quite a long time....No web surfing, d.loading or game playing...just YouTube video watching. Can this battery be changed out? The first nextbook the battery quit in, I took it apart - the battery was glued & the speaker wires were attached just as you described.
    stephanieethall - Réponse
    Start on the side opposite the Power and Volume controls. And try not to push the Power and Volume controls on whatever surface you’re using to stabilize/hold the tablet during removal of the back cover. Otherwise you will turn the tablet ON, or get it into DNX Mode.
    Tim Tillotson - Réponse
  2. Remplacement de la vitre du Nextbook 8: étape 2, image 1 de 2 Remplacement de la vitre du Nextbook 8: étape 2, image 2 de 2
    • Retirez le ruban adhésif recouvrant la carte mère.
    • Retirez le ruban argenté fixant les câbles blancs à la batterie.
  3. Remplacement de la vitre du Nextbook 8: étape 3, image 1 de 2 Remplacement de la vitre du Nextbook 8: étape 3, image 2 de 2
    • Utilisez un spudger pour déconnecter avec précaution le connecteur de la batterie de la carte mère.
    • Lorsque vous travaillez avec des composants électroniques, il est important de choisir un outil sans danger pour les décharges électrostatiques afin d'éviter toute détérioration accidentelle du périphérique. Le spudger en nylon noir ordinaire ou un outil d’ouverture en plastique doivent être utilisés dans la mesure du possible.
    Why the five wires when most batterys have 2-3. What do the five wires do. Thank you
    Ronald Grasse - Réponse
  4. Remplacement de la vitre du Nextbook 8: étape 4, image 1 de 1
    • Utilisez un spudger pour relever la barre noire des deux connecteurs ZIF situés au-dessus de la batterie
    • Tirez les câbles ruban hors des connecteurs avec des pincettes ou deux doigts.
  5. Remplacement de la vitre du Nextbook 8: étape 5, image 1 de 2 Remplacement de la vitre du Nextbook 8: étape 5, image 2 de 2
    • À l'aide du bout plat d'un spudger, placez soigneusement le spudger sous la batterie et retirez-le de l'appareil.
    • La batterie est très malléable, ne tentez donc pas de la retirer en une fois.
    Also some models have the battery glued down. You'll need to work on trying to pull up the glue work in a circle going around the edge of the battery it was tough you can damage your battery if you do not do this step carefully
    Mr. DeWray - Réponse
    What type of battery ? Watch battery?
    dheltebran - Réponse
  6. Remplacement de la vitre du Nextbook 8, Ecran: étape 6, image 1 de 1
    • Retirez l’autocollant argent et or au bas de l’appareil.
    • Maintenez le circuit imprimé brun avec votre doigt pendant que vous retirez l'autocollant
  7. Remplacement de la vitre du Nextbook 8: étape 7, image 1 de 2 Remplacement de la vitre du Nextbook 8: étape 7, image 2 de 2
    • Utilisez un spudger pour soulever les pattes noires des trois connecteurs ZIF.
    • Utilisez des pincettes de sécurité antistatique pour extraire les câbles ruban des trois connecteurs.
  8. Remplacement de la vitre du Nextbook 8: étape 8, image 1 de 2 Remplacement de la vitre du Nextbook 8: étape 8, image 2 de 2
    • Retirez les 5 vis noires de la carte mère.
    • Soulevez délicatement la carte mère de l'appareil et retirez-la.
  9. Remplacement de la vitre du Nextbook 8: étape 9, image 1 de 2 Remplacement de la vitre du Nextbook 8: étape 9, image 2 de 2
    • Retirez les deux vis qui maintiennent les supports en place.
    • Retirez les deux supports en argent qui maintiennent l’écran en place.
  10. Remplacement de la vitre du Nextbook 8: étape 10, image 1 de 2 Remplacement de la vitre du Nextbook 8: étape 10, image 2 de 2
    • Retirez la vis argentée du petit circuit imprimé vert situé au bas de l'appareil.
    • Mettez de côté le petit circuit imprimé pour l'instant.
  11. Remplacement de la vitre du Nextbook 8: étape 11, image 1 de 1
    • Retirez les deux vis argentées situées au bas de l'appareil.
  12. Remplacement de la vitre du Nextbook 8: étape 12, image 1 de 3 Remplacement de la vitre du Nextbook 8: étape 12, image 2 de 3 Remplacement de la vitre du Nextbook 8: étape 12, image 3 de 3
    • Avec l’appareil face vers le bas, utilisez un spudger pour soulever l’écran du verre du côté droit.
  13. Remplacement de la vitre du Nextbook 8, Vitre: étape 13, image 1 de 1
    • Séparez le verre de l'écran tactile.
Pour remonter votre appareil, suivez ces instructions dans l’ordre inverse.
12 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Dylan Wiese
Membre depuis le 03/11/15
1 871 Réputation
5 tutoriels rédigés
Équipe
Colorado Springs, Team 5-1, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 5-1, Panko Spring 2015
UCCS-PANKO-S15S5G1
3 membres
10 tutoriels rédigés
6 commentaires de tutoriel
Thank you for this!
Samuel Landers - Réponse
Ok thanks for the guide very helpful. Where can I pick a glass up at? And what's the going price?
mikediehl99 - Réponse
My repair kit has specifically the touch glass meaning i need to separate the glass form the frame, how do you do this?
Tanther Panther - Réponse
I just found the frame can be separated from the glass with a spudger-type thing, I used a fine blade like a craft knife (be careful!!). started at the bottom inside end and worked my way around, trying not to damage the frame in the process. Just to clarify this is for the NX785QC8G.
The glass is attached to the frame with adhesive, so the new glass will need to be stuck back on in a similar way. It’s strange that this part wasn’t mentioned in the instructions, as it was supposed to be for replacing the actual glass digitiser screen, but didn’t quite get there… hope this is of some help.. although it’s 2021 now and you’ve probably gone and bought a new one lol ;) I love my tablet (well, my 4yr-old does) but I stood on it and I happened to have a digitiser on hand.
Sarah Bee -
I need a screen replacement guid like this one but for the Nextbook Ares 8 not 8a
Isaac De La Cruz - Réponse
My replacement screen is listed for this model but it's just glass and a connector. No frame like one the came off tablet (no place for screw or to connect back cover) did I get wrong screen? Listing had it as the nx785qc8g.
travis.fox86 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 6,084
