Aller au contenu principal
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Remplacement des caméras arrière de l'iPhone 12 mini
Ce dont vous avez besoin
  1. Remplacement des caméras arrière de l'iPhone 12 mini, Dévisser les vis Pentalobe: étape 1, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Dévisser les vis Pentalobe: étape 1, image 2 de 2
    • Avant de commencer, déchargez votre iPhone en dessous de 25 %. Une batterie lithium-ion chargée peut prendre feu et/ou exploser si elle est accidentellement percée.
    • Éteignez votre iPhone avant de commencer à le démonter.
    • Dévissez les deux vis Pentalobe de 6,7 mm en bas de l'iPhone.
    is it oem apple battery, because at some photo shows(Ifixit) and another shows (apple) ... wait your answer?
    karim - Réponse
    BEWARE! This screen isn’t the same as older iPhone models’ screens. The iPhone mini 12-screen comes with a thin plastic frame around the screen on its back. Thus, make sure you don’t insert the pick in between the screen and its plastic frame, as you’ll seperate the screen and leave the plastic frame still sitting in the phone’s metal housing (this cost me 100 dollars…). Carefully heat the sides of the metal housing and do not heat directly on the glass, as doing so will potentially loosen the glue from the plastic frame stuck to the screen. My suggestion is that you watch a video of this repair as this step-by-step-guide is undercooked.
    Dan - Réponse
    This is an excellent comment. Following this step-by-step guide to the letter will break your screen; it's by far the worst iFixit guide I've seen to date.
    Dormouse -
    Ive finished mine and Soooo absolutely dont do this yourself🙌🏽 unless your a mechanic because first of all they didnt send me all of the right tools🤗 and secondly the battery they gave me has an overly large component so it wont fit into my phone. And the absolute HASSEL i had to go through to even just get the package was insane it was a whole month of struggling just for the stuff to not even be right, in conclusion will NEVER order from here again..🤗
    Chanell - Réponse
  2. Remplacement des caméras arrière de l'iPhone 12 mini, Marquer vos médiators: étape 2, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Marquer vos médiators: étape 2, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Marquer vos médiators: étape 2, image 3 de 3
    • S'il est inséré trop loin, un médiator risque d'endommager votre appareil. Suivez cette étape pour tracer un repère sur votre médiator et éviter que l'appareil ne soit endommagé.
    • Mesurez 3 mm à partir de la pointe et tracez une ligne sur le médiator avec un marqueur permanent.
    • Vous pouvez également marquer les autres coins du médiator avec des mesures différentes.
    • Une autre solution consiste à scotcher une pièce de monnaie sur votre médiator, à 3 mm de la pointe.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Réponse
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Réponse
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Réponse
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Réponse
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Réponse
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Réponse
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Réponse
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Réponse
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Réponse
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Réponse
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Réponse
  3. Remplacement des caméras arrière de l'iPhone 12 mini, Recouvrir toutes les fissures: étape 3, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Recouvrir toutes les fissures: étape 3, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Recouvrir toutes les fissures: étape 3, image 3 de 3
    • Si votre écran iPhone 12 mini est fissuré, empêchez les fissures de s'aggraver et les éclats de vous blesser en le recouvrant de ruban adhésif.
    • Recouvrez l'écran de bandes de ruban adhésif, qui se chevauchent, jusqu'à ce que toute la surface soit couverte.
    • Portez des lunettes de sécurité pour vous protéger les yeux des éclats de verre tout au long de la réparation iPhone.
    • Si la ventouse n'adhère pas au cours des étapes suivantes, pliez un morceau de ruban adhésif épais (du ruban adhésif toilé p.e.) pour former une poignée et soulevez l'écran de cette façon.
    • Si tout cela échoue, vous pouvez coller la ventouse à l'écran avec de la superglue.
  4. Remplacement des caméras arrière de l'iPhone 12 mini, Instructions pour Anti-Clamp: étape 4, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Instructions pour Anti-Clamp: étape 4, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Instructions pour Anti-Clamp: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • Les trois étapes suivantes montrent comment utiliser l'Anti-Clamp, un outil conçu pour faciliter la procédure d'ouverture. Si vous n'utilisez pas l'Anti-Clamp, sautez ces trois étapes pour une autre méthode.
    • Pour des instructions complètes sur l'utilisation de l'Anti-Clamp, suivez ce tutoriel.
    • Tirez la poignée bleue vers l'arrière pour débloquer les bras de l'Anti-Clamp.
    • Insérez le côté droit ou gauche de votre iPhone entre les bras.
    • Positionnez les ventouses près du bas de l'écran iPhone : une devant, une derrière.
    • Appuyez sur les ventouses pour faire le vide à l'endroit désiré.
    • Si vous trouvez que la surface de votre appareil est trop glissante pour que l'Anti-Clamp y adhère, vous pouvez utiliser du ruban adhésif pour obtenir une surface plus agrippante.
  5. Remplacement des caméras arrière de l'iPhone 12 mini: étape 5, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini: étape 5, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini: étape 5, image 3 de 3
    • Tirez la poignée bleue vers l'avant pour bloquer les bras.
    • Tournez la poignée dans le sens horaire de 360 degrés ou bien jusqu'à voir les ventouses se tendre.
    • Vérifiez que les ventouses restent bien alignées entre elles. Si elles commencent à se décaler, détachez-les pour les réaligner.
  6. Remplacement des caméras arrière de l'iPhone 12 mini: étape 6, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini: étape 6, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini: étape 6, image 3 de 3
    • Posez votre iPhone sur quelque chose de solide comme un livre à couverture rigide, pour qu'il tienne tout seul à l'horizontale. Ainsi, il sera plus facile de procéder aux étapes suivantes.
    • Servez-vous d'un sèche-cheveux pour faire chauffer le bord inférieur de l'iPhone. L'écran doit être légèrement trop chaud au toucher.
    • Attendez une minute pour donner à l'adhésif le temps de se détendre et d'ouvrir un interstice.
    • Insérez un médiator sous le joint en plastique de l'écran, dès que l'Anti-Clamp a ouvert un interstice suffisant.
    • Assurez-vous que le médiator est correctement placé entre le joint en plastique et le châssis, pour éviter d'endommager votre écran.
    • Si l'interstice ne suffit pas, faites encore chauffer la zone et tournez la poignée d'un quart de tour.
    • Ne tournez jamais de plus d'un quart de tour et attendez une minute à chaque fois. Laissez l'Anti-Clamp et le temps faire le travail à votre place.
    • Passez les trois étapes suivantes.
  7. Remplacement des caméras arrière de l'iPhone 12 mini, Chauffer le bord inférieur du téléphone: étape 7, image 1 de 1
    • Ouvrir l'écran iPhone va endommager ses joints étanches. Pensez à vous procurer des joints de remplacement avant de vous lancer dans une réparation, ou bien faites attention à ne plus exposer votre iPhone à des liquides si vous le remontez sans changer les joints.
    • Chauffer le bord inférieur de l'iPhone va aider à ramollir l'adhésif qui fixe l'écran et donc faciliter l'ouverture.
    • Utilisez un sèche-cheveux ou un pistolet thermique pour chauffer le bord de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
    • Ne pointez jamais votre sèche-cheveux au même endroit pendant un temps prolongé.
    • Si vous avez du mal au cours de la procédure d'ouverture, il est très probable que l'adhésif ait refroidi et durci. Refaites chauffer pour continuer à le ramollir.
    you need to clarify that you're heating the metal frame, not the glass. I gently heated the glass front with a heat gun and proceeded to pull the display apart, destroying it. :-(
    Jim Harger - Réponse
  8. Remplacement des caméras arrière de l'iPhone 12 mini, Poser une ventouse: étape 8, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Poser une ventouse: étape 8, image 2 de 2
    I would recommend starting with a bottom corner, not the bottom middle. If the adhesive isn't softened enough, you will pull the middle out but the sides will still be stuck on, causing extreme flex to the panel and damage to the panel down the middle (white bars down the middle in a worst case). I did this to my phone.
    Drew Kosir - Réponse
  9. Remplacement des caméras arrière de l'iPhone 12 mini, Soulever  légèrement l'écran iPhone 12 mini: étape 9, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Soulever  légèrement l'écran iPhone 12 mini: étape 9, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Soulever  légèrement l'écran iPhone 12 mini: étape 9, image 3 de 3
    • Tirez fermement et constamment sur la ventouse pour ouvrir un léger espace entre l'écran et le châssis métallique.
    • Un cadre en plastique est fixé sous l'écran et doit être soulevé avec l'écran. L'insertion d'un médiator entre le cadre et l'écran endommagerait le panneau.
    • Insérez un médiator dans l'interstice sous le cadre en plastique de l'écran.
    • Assurez-vous que le médiator est placé sous le cadre plastique (contre le châssis) pour éviter d'endommager votre écran.
    • L'adhésif étanche qui fixe l'écran est très tenace. Ouvrir ce petit espace nécessitera de forcer quelque peu. Si vous avez du mal, chauffez plus et faites jouer l'écran de haut en bas, pour faire céder l'adhésif et créer l'espace destiné à votre outil.
    I ended up separating my screen rather than getting under the scren casing.. BE CAREFUL TO MAKE SURE YOU ARE UNDER THE PLASTIC PART - otherwise you just ruin your screen... No mention of this precaution here and as a result, my phone is more broken than when I started
    Tyler Ludwig - Réponse
    Hi, I don’t get it. Should the plastic part stay with the display or with the phone?
    Paul - Réponse
    The plastic frame should stay with the display.
    Carsten Frauenheim -
    Be sure you see two layers: glas and plastic (Step 6, Clamp, last picture). You have to go underneath the plastic frame otherwise you are tearing your displayglas off the frame and destroy your OLED!
    Johnny RS - Réponse
    Broke the screen. Too bad. I've done maybe 5 battery replacements before. But this one is very very tight. Got a new phone. :P
    Gilles van Leeuwen - Réponse
    Same thing, I broke my screen too. I think the warning should be in all caps and show more clearly where is the right place to put the pick and where is not — without the need to click on the link.
    Judging by amount of people who reported it here (and should also account for those who didn't bother to report), I'd say that there is a problem with instructions.
    It is honestly not so hard if you know what does mistake looks like and that it is possible to separate the screen so easily from the frame. I repaired more than a dozen phones — screens and batteries — and this is the first time I made such a mistake that costs 100+euros.
    Axel Mort - Réponse
  10. Remplacement des caméras arrière de l'iPhone 12 mini, Chauffer le bord droit: étape 10, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Chauffer le bord droit: étape 10, image 2 de 2
    • Utilisez un sèche-cheveux pour chauffer le bord droit de l'iPhone (celui avec le bouton de marche) pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
    The pictures show the left side. I know that the left side is the correct one to heat, but for others it might be confusing. 😊
    Donát Viosz - Réponse
    @dviosz You mean the right edge! The picture shows the left edge but the right edge is the correct one to heat. As described in the text next to it. Opening the phone from the left will damage it!
    catchMyException - Réponse
    Yeah, sorry, you are right! (tried to make something less confusing and created more confusion by accident… 😃 )
    Donát Viosz -
    THIS ONE HERE (lolz)
    weebeast -
  11. Remplacement des caméras arrière de l'iPhone 12 mini, Décoller l'adhésif de l'écran: étape 11, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Décoller l'adhésif de l'écran: étape 11, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Décoller l'adhésif de l'écran: étape 11, image 3 de 3
    • Faites glisser le médiator le long du coin inférieur droit et du bord droit de l'iPhone, en tranchant l'adhésif qui maintient l'écran en place.
    • N'enfoncez pas votre médiator de plus de 3 mm, car vous risquez d'abîmer les composants internes.
    Be very careful your tool does NOT go in between the screen and the screen frame but rather in between the screen frame and the phone frame. If not you will damage the screen and need a new one. This has happened to MANY people. The screen is attached to the screen frame with an adhesive that can also be accidentally pried apart if not done carefully. This is probably more likely if your tool is too thin, if you dont heat enough, or dont suction and pull enough to create a big enough separation between the screen frame and the phone frame.
    Ezra Gilbert - Réponse
    Yes, this happens to me, too. It took a long time until I could remove the screen using a heat gun with a heat gun set to 120°C (after trying first with 90° and 100°). Now the right side of the display shows white stripes and the touch doesn't react. -> New display necessary...
    Bernd Löhr - Réponse
  12. Remplacement des caméras arrière de l'iPhone 12 mini, Chauffer le bord supérieur: étape 12, image 1 de 1
    • Utilisez un sèche-cheveux pour chauffer le bord supérieur de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
  13. Remplacement des caméras arrière de l'iPhone 12 mini: étape 13, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini: étape 13, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini: étape 13, image 3 de 3
    • Le bord supérieur de l'écran est fixé à la fois par de la colle et des clips.
    • Insérez votre médiator sous le coin supérieur droit de l'écran.
    • Faites glisser le médiator autour du coin supérieur droit. Vous devriez rencontrer de la résistance en raison des clips.
    • N'enfoncez pas votre médiator de plus de 3 mm, car vous risquez d'abîmer les capteurs frontaux.
    • Pousser délicatement le panneau frontal vers le bas du téléphone facilite quelque peu la manipulation.
    • Parcourez le bord supérieur avec le médiator et finissez de trancher l'adhésif qui fixe l'écran.
  14. Remplacement des caméras arrière de l'iPhone 12 mini, Chauffer le bord gauche: étape 14, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Chauffer le bord gauche: étape 14, image 2 de 2
    • Utilisez un sèche-cheveux pour chauffer le bord gauche de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
  15. Remplacement des caméras arrière de l'iPhone 12 mini, Informations écran iPhone 12 mini: étape 15, image 1 de 1
    • Il y a deux nappes fragiles le long du bord gauche de votre iPhone, l'une près du haut et l'autre légèrement en dessous du milieu. N'y insérez pas votre médiator, car vous risquez de les endommager.
    There are two cables, one near the top, another lower than the middle on the left side. Further steps show where the second one is, but this picture doesn't show it...
    mesanos - Réponse
    Welches Ersatzteil benötige ich, wenn die obere Verbindung gerissen ist?
    Claudia T. - Réponse
    If the inside of your phone looks different than these photos (like me) then you may have only removed the top layer of the screen assembly. The bottom layer should pry up easily enough with tweezers.
    macro - Réponse
    I accidentally tore the cables off. What can I do?
    Alma Hernandez - Réponse
    The display flexy is in the middle of the left side, please update the picture showing the flexy connected and highlight in red, so other users don't damage it as I did :(
    Juan David Zuluaga - Réponse
    Updated -- thank you! Does this look better?
    Spencer Pennington -
  16. Remplacement des caméras arrière de l'iPhone 12 mini, Séparer l'adhésif du bord gauche: étape 16, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Séparer l'adhésif du bord gauche: étape 16, image 2 de 2
    • Insérez un second médiator dans le coin inférieur gauche de l'iPhone.
    • Faites pivoter les deux médiators en même temps, jusqu'à ce que les clips du bord gauche se détachent.
    • Faites pivoter en augmentant graduellement la force.
    • Si vous avez de mal, refaites chauffer le bord gauche.
    Don't go from just one corner (like on the right side). I've done that (forgot this step) and broke my screen.
  17. Remplacement des caméras arrière de l'iPhone 12 mini, Ouvrir l'iPhone: étape 17, image 1 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Ouvrir l'iPhone: étape 17, image 2 de 3 Remplacement des caméras arrière de l'iPhone 12 mini, Ouvrir l'iPhone: étape 17, image 3 de 3
    • Tournez votre iPhone de façon que son bord droit est en face de vous.
    • Ouvrez l'iPhone en soulevant le côté droit de l'écran comme on ouvre la couverture avant d'un livre.
    • N'essayez pas encore d'enlever complètement l'écran, car il est toujours relié à la carte mère de l'iPhone par plusieurs nappes fragiles.
    • Calez l'écran contre un objet pour qu'il reste ouvert pendant que vous travaillez sur votre téléphone.
    • Lors du remontage, posez l'écran à sa place, alignez les clips le long du bord supérieur et commencez par insérer soigneusement ce bord avant de refermer tout l'écran. Si ce dernier ne s'enclenche pas facilement, vérifiez que les clips sur son périmètre n'ont pas été déformés.
  18. Remplacement des caméras arrière de l'iPhone 12 mini, Dévisser le cache des connecteurs de la batterie et de l'écran: étape 18, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Dévisser le cache des connecteurs de la batterie et de l'écran: étape 18, image 2 de 2
    Magnetic Project Mat
    $19.95
    • Ôtez la vis Y000 de 1,25 mm qui fixe le cache des connecteurs de la batterie et de l'écran.
    • Tout au long de cette réparation, gardez la trace de chacune des vis et veillez à les revisser toutes là où elles étaient auparavant pour éviter d'endommager votre appareil.
    • Lors du remontage, voici venu le bon moment pour allumer votre iPhone et tester si tout fonctionne avant de sceller à nouveau l'écran. Pensez à rééteindre complètement votre iPhone avant de reprendre le remontage.
    hallo, ich sehe in Schritt 17 nur EINE markierte Schraube... (?)
    marrei1964 - Réponse
    So i got the kit how do you expect with the tools you gave me i should get that tiny screw out?? Its requires a 3 way screw i have a 4 and 2 5 ways 🤔
    Chanell - Réponse
    This Shield is garbage and once it's taken out it's next to impossible to get back in. I'm not even going to put the shield back in I'm just going to put kapton tape over it and call it good.
    Zach Benson - Réponse
  19. Remplacement des caméras arrière de l'iPhone 12 mini, Ôter le cache des connecteurs de la batterie et de l'écran: étape 19, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Ôter le cache des connecteurs de la batterie et de l'écran: étape 19, image 2 de 2
    • Prenez une pincette pour retirer le cache des connecteurs de la batterie et de l'écran.
    • Il y a deux petites charnières le long du bord droit du cache. Veillez à les aligner avec leurs pendants lors du remontage.
  20. Remplacement des caméras arrière de l'iPhone 12 mini, Débrancher la batterie: étape 20, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Débrancher la batterie: étape 20, image 2 de 2
    • Prenez une spatule (spudger) ou un ongle propre pour soulever le connecteur de la batterie de sa prise sur la carte mère.
    • Essayez de ne pas abîmer les joints en silicone noir qui entourent cette connexion et d'autres sur la carte mère. Ils assurent une protection supplémentaire contre l'intrusion d'eau et de poussière.
    • Repliez légèrement le connecteur par rapport à la carte mère pour l'empêcher de faire accidentellement contact avec la prise et d'alimenter le téléphone pendant que vous effectuez votre réparation.
  21. Remplacement des caméras arrière de l'iPhone 12 mini, Débrancher l'écran OLED: étape 21, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Débrancher l'écran OLED: étape 21, image 2 de 2
    • Servez-vous d'une spatule ou d'un ongle pour débrancher le connecteur de la nappe du panneau OLED de sa prise sur la carte mère.
    • Pour rattacher un connecteur à emboîter comme celui-ci, alignez-le soigneusement et appuyez d'un côté jusqu'à ce qu'il s'emboîte, puis recommencez de l'autre côté. N'appuyez pas au milieu. Si le connecteur n'est pas aligné correctement, les broches risquent de se déformer et de causer des dégâts irréversibles.
  22. Remplacement des caméras arrière de l'iPhone 12 mini, Dévisser le cache de l'ensemble capteurs frontaux: étape 22, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Dévisser le cache de l'ensemble capteurs frontaux: étape 22, image 2 de 2
    • Enlevez les cinq vis Y000 de 1 mm qui fixent le cache de l'ensemble capteurs frontaux.
    There is an error here. There are different screws. 2 large and 3 small.
    zeidin09 - Réponse
    what 3 are the small ones? I don't know anymore
    Thomas Klep - Réponse
    in case anyone else reads this, the 3 small ones screw directly onto the board. the two longer ones screw into standoffs (the two top screws, based on the picture above)
    Skyejobs -
  23. Remplacement des caméras arrière de l'iPhone 12 mini: étape 23, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini: étape 23, image 2 de 2
    • Prenez une pincette pour ôter le cache de l'ensemble capteurs frontaux.
  24. Remplacement des caméras arrière de l'iPhone 12 mini, Déconnecter les capteurs frontaux: étape 24, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Déconnecter les capteurs frontaux: étape 24, image 2 de 2
    • Prenez la pointe d'une spatule ou un ongle propre pour débrancher la nappe de l'ensemble capteurs frontaux.
  25. Remplacement des caméras arrière de l'iPhone 12 mini, Ôter l'ensemble écran: étape 25, image 1 de 1
  26. Remplacement des caméras arrière de l'iPhone 12 mini, Dévisser le cache du module caméras arrière: étape 26, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Dévisser le cache du module caméras arrière: étape 26, image 2 de 2
    • Dévissez les deux vis cruciformes #000 de 1,6 mm de long.
  27. Remplacement des caméras arrière de l'iPhone 12 mini, Ôter le cache du module caméras arrière: étape 27, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Ôter le cache du module caméras arrière: étape 27, image 2 de 2
    • Avec une pincette, retirez le cache du module caméras arrière.
    • Sur la droite du cache, deux petits crochets s'insèrent dans le rebord de l'iPhone. Saisissez le cache du côté gauche et tirez-le dans la direction des boutons de volume afin de le retirer en toute sécurité.
    • Lors du remontage, assurez-vous d'aligner les deux crochets dans les attaches correspondantes dans le rebord de l'iPhone.
  28. Remplacement des caméras arrière de l'iPhone 12 mini, Débrancher les nappes: étape 28, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Débrancher les nappes: étape 28, image 2 de 2
    • Les nappes des caméras arrière de l'iPhone 12 mini sont posées les unes sur les autres et doivent donc être débranchées puis rebranchées dans le bon ordre.
    • Faites levier sur la nappe de la caméra ultra grand-angle à la verticale avec une spatule, pour la débrancher de sa prise.
  29. Remplacement des caméras arrière de l'iPhone 12 mini: étape 29, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini: étape 29, image 2 de 2
    • Faites levier sur la nappe de la caméra grand-angle à la verticale avec la spatule, pour la déconnecter de sa prise.
  30. Remplacement des caméras arrière de l'iPhone 12 mini, Faire levier sur le module caméras arrière: étape 30, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Faire levier sur le module caméras arrière: étape 30, image 2 de 2
    • Insérez la pointe de la spatule entre le bord supérieur du module et le rebord de l'iPhone.
    • Inclinez la spatule vers le bas pour soulever le module caméras arrière hors de sa cavité.
  31. Remplacement des caméras arrière de l'iPhone 12 mini, Ôter le module caméras arriére: étape 31, image 1 de 2 Remplacement des caméras arrière de l'iPhone 12 mini, Ôter le module caméras arriére: étape 31, image 2 de 2
    • Retirez le module à l'aide d'une pincette.
Comparez votre pièce de remplacement à la pièce d'origine. Il vous faudra peut-être transférer d'éventuels composants restants ou retirer des films adhésifs de la nouvelle pièce avant de commencer le remontage.
Pour remonter votre appareil, suivez ces instructions en sens inverse. Nettoyez les zones d'adhérence avec de l'alcool isopropylique (> 90 %) et posez une nouvelle couche d'adhésif là où c'est nécessaire.
Déposez vos déchets électroniques dans un centre de recyclage certifié.
La réparation ne s’est pas déroulée comme prévu ? Consultez nos conseils basiques de diagnostic ou la section iPhone 12 mini de notre Forum pour obtenir de l’aide.
13 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
86%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Dominik Schnabelrauch
Membre depuis le 11/23/16
228 969 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 415 tutoriels rédigés
5 commentaires
Removing these screens is no joke folks. There is a backing on the screen that is also adhered to the phone casing, and it is very easy to separate this from the front of the screen, destroying or at the very least damaging it in the process.
Hunter Strathman - Réponse
Once the stupid screen is off, it's an easy task. I wasn't able to get it off without the clamp. So I would order the clamp straight away with it!
Robertvo - Réponse
I managed to replace the camera. Now I am stuck with a not functioning foto app, that won't save pictures and a really slow loading time generally. Also I can not switch to wide angle camera mode. how do I fix this?
Max von Nordheim - Réponse
Will you get the "Finish Repairing Your Camera" warning with Ifixit rear camera part?
Tim - Réponse
Yeah head the warnings about the screen, destroyed my screen trying to open this.
Nathan Nohr - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 31
7 derniers jours : 207
30 derniers jours : 979
Total : 37,027
