Aller au contenu principal
Samsung Galaxy S5 microSD Card Replacement
Justin Uchimura
Justin Uchimura et 5 autres contributeurs
Dernière mise à jour le January 24, 2025
1 minute
Très facile
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
For the official iFixit guide to repair your Galaxy S5 nicroSD card, click here. The guide you are currently viewing is duplicate content, archived here for historical purposes only.
Ce dont vous avez besoin
Outils
  1. Samsung Galaxy S5 microSD Card Replacement, Battery: étape 1, image 1 de 3 Samsung Galaxy S5 microSD Card Replacement, Battery: étape 1, image 2 de 3 Samsung Galaxy S5 microSD Card Replacement, Battery: étape 1, image 3 de 3
    • Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
    • Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
    Nice work for my phone setting
    BhupSinghBhadu Baf - Réponse
    Thanks very much A better replace ment
  2. Samsung Galaxy S5 microSD Card Replacement: étape 2, image 1 de 2 Samsung Galaxy S5 microSD Card Replacement: étape 2, image 2 de 2
    • Lift the battery upward with your finger or plastic opening tool by pushing on the notch located on the bottom of the battery.
    • Remove the battery from the phone.
  3. Samsung Galaxy S5 microSD Card Replacement, microSD Card: étape 3, image 1 de 3 Samsung Galaxy S5 microSD Card Replacement, microSD Card: étape 3, image 2 de 3 Samsung Galaxy S5 microSD Card Replacement, microSD Card: étape 3, image 3 de 3
    • Gently slide out the SD card using your fingernail or a plastic opening tool.
    • For reassembly, gently slide in the microSD card until it stops.
    Thanks for useful setting
5 autres ont terminé cette réparation.
Justin Uchimura
Membre depuis le 04/22/14
4 428 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 10-57, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 10-57, Amido Spring 2014
CPSU-AMIDO-S14S10G57
4 membres
12 tutoriels rédigés
1 commentaire de tutoriel
Actually the battery does not even have to be removed (just unmount in settings first to avoid corruption)
Simply slide the card back until it runs into the battery, then just lift out.
BFeely - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 4
Total : 4,642
