Introduction
Passez à l'étape 1This guide contains a selection of photos and chip identification summary for the main board of Valve's Steam Deck.
Check out our Steam Deck Teardown for more details.
Special thanks to community member CChin for his contribution!
Vidéo d'introduction
IC Identification, Pt. 1:
AMD/Valve 100-000000405 Quad-Core Application Processor w/ GPU
Micron MT62F1G32D4DR-031 WT:B 4 GB LPDDR5 SDRAM Memory
Winbond W25Q128JW 16 MB Serial NOR FLASH Memory
Analogix ANX7580 DisplayPort to Single MIPI Receiver
Cirrus Logic CS35L41B Audio Amplifier
Maxim Integrated MAX77961 USB Type-C Li-Ion Battery Charger
O2Micro OZ536 Backlight LED Driver
IC Identification, Pt. 2:
Monolithic Power Systems MP2845 Digital 6-Phase Controller
Monolithic Power Systems MP86902B 35 A Power Stage
Monolithic Power Systems MP86903C Power Stage
Likely Monolithic Power Systems NB688C Synchronous Buck Converter
Monolithic Power Systems NB691 Synchronous Buck Converter
Monolithic Power Systems NB690G Synchronous Buck Converter
Possibly Monolithic Power Systems NB591 Synchronous Buck Converter
IC Identification:
ITE Tech IT5570VG Embedded Controller (likely)
O2Micro OZ711 Card Reader Controller
Maxim Integrated MAX77958 USB Type-C & USB Power Delivery Controller
Diodes Incorporated PI3USB102 USB 2.0 SPDT Analog Switch
Texas Instruments TPS22976 Load Switch
En el caso del Texas Instruments TPS22976 Interruptor de carga, se trataría de un componente alternativo al original (XDZK)? O por lo menos no coincide la disposición física.
25 commentaires
Interesting how Valve went with a full-custom APU from AMD. I thought they’d use an off-the-shelf chip like the 4500U.
Yeah i know what you mean!
They most likely they where wanting it to not be that thick,
so not like a laptop or desktop CPU for it,
Due to it being kinda thick!
I assume the only major difference between this and an off the shelf APU is that this APU just has everything the steam deck does not utilize disabled or removed for power consumption reasons. I doubt it goes much deeper than that.
Alyx -
Good Point
See what you mean
The 4500u has 6 EC Vega GPU, while the Steameck APU has an 8 ECU RDNA 2 GPU. Plus the custom APU gives them more control than a OTS apu.
There are actually some differences, it has many differences than typical off-the-shelf APUs, now I don't know how much is firmware and how much is actually silicon but they had a section with AMD engineers that go into detail, some of my takeaways is that inbetween cycles, if it's done doing what it was it goes into a very low power mode, and the other one being that they really went for consistency and not turbo clocks and stuff
Scribble -
There’s not much to disable.
And it’s probably not custom APU for them, but something that Dell haven;t bought.
They needed to go to this strange mix of zen2+radeon6xxx mix, because only zen2 was low-power then and starting from radeon 6xxxx it provides RayTracing and is more energy efficient then older chips.
Mobile zen3 wasn’t released then. Now they would go this route.
Microsoft, not Dell. Rumour has it that this was a part originally designed for an MS mobile device that the pandemic killed off: hence the presence of a machine vision IP block on the die that the Deck doesn't use and is most unlikely ever to.
what about USB C port repair. doesnt seem like a simple thing . specially if ud end up replacing the whole board.
Hmm idk,
I bet its on the logic board
Не вижу проблемы поменять порт usb C. Сплав Розе вам для скорости
FixMan -
It's replaceable, :D
On the lower right side of the "side 1"
Is the WI-FI card port
Yes, ifixit has them.
I'd like to know what the USB controller for this thing is. The PD controller is labeled, and it seems there's a USB 2.0 de/multiplexor in there that's labeled. But...nothing USB 3? Does the USB C signal just go straight to the APU or something??
Hmm.
that's a possibility!
I have No Idea
Where I can buy the Maxim Integrated MAX77961 charger USB C?
Guys, anyone khow what kind of ssd controller SD have. I heard that if u connect SSD with >1.6 A. Your SD SSD controller burnt. Any info. THX
Does anyone know where can I buy a MAX77961 IC?
The OLED version has a Nuvoton NAU88L21YG audio codec chip on the motherboard. No codec chip is present in this publication for the LCD model but looking at the x-ray images, it seems the chip is actually on the headphone board for the LCD model. They also missed some other chips from other boards.
While I commend VALVE for being a leader in making the most beautiful and simple machine to replace component's in, they lead the field in self repair, but Why is there NO schematics for repairers like me or anyone else in the field of Micro repair for the motherboard, I have been working on a Steam Deck Motherboard with no success as I am working blind as the board is black it's almost impossible to track down the traces, So I ASK valve PLEASE release the schematics for the motherboards,
Thank You Millenium Micro Repairs
Does anyone know where I can get chip PI3USB102 from? It's on aliexpress but the pin set up looks different to the motherboard pin set up
Can i buy a part? Part name is Analogix ANX7580 DisplayPort to Single MIPI Receiver
MUHAMMAD FIKRI HAIKAL - Réponse
