Aller au contenu principal
Toshiba Satellite C855-S5115 Keyboard Replacement
Claire Fletcher
Claire Fletcher et 2 autres contributeurs
Dernière mise à jour le December 29, 2022
15 minutes
Modérée
A besoin de meilleures images
Sticking and broken keys means it might be time for a new keyboard. This guide will show you how to remove and replace you Toshiba's keyboard.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Afficher plus…
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: étape 2, image 1 de 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: étape 3, image 1 de 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: étape 3, image 2 de 2
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
    Use the tool on the user side of the board. See the connector below. Notice the small lndents on the very edge of the board to the right of the connector. That's where to use the tool on the left, right and bottom (user side). 7 on the user edge and 1 each on the left and right edges about a third of the way from the screen edge.
    igfar bullammy - Réponse
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite C855-S5115 Keyboard Replacement: étape 4, image 2 de 2
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite C855-S5115 Keyboard Replacement: étape 5, image 2 de 2
    • Pull out the connector attaching the keyboard to the main body of the laptop.
    To remve the ribbon unlock the 2 small grey tabs on each end. The tabs are unlocked by gently moving them forward. GENTLY!
Claire Fletcher
Membre depuis le 04/05/18
988 Réputation
7 tutoriels rédigés
2 commentaires de tutoriel
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - Réponse
Do you have to do anything with the connector before removing?
William - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 2,810
