Aller au contenu principal
Vizio SmartCast Crave 360 Battery Replacement
Pavani Lopez Leon
Pavani Lopez Leon et 3 autres contributeurs
Dernière mise à jour le December 19, 2022
45 minutes
Modérée
If you have trouble powering on or keeping a charge with your SmartCast Crave 360 (model SP50-DP), use this guide to replace its battery. The battery will hold a certain amount of charge in order to turn the speaker on. If your speaker is not fully charged, refer to the troubleshooting page as the battery may still be working. If the battery is completely dead and will not charge, this guide will show you how to replace it so you can continue using your speaker.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
Afficher plus…
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: étape 1, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: étape 1, image 2 de 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: étape 2, image 1 de 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: étape 3, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: étape 3, image 2 de 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
    Anyone know the ribbon cable part number if damaged ?
    James Middlemiss - Réponse
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: étape 4, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Bass: étape 4, image 2 de 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: étape 5, image 1 de 3 Vizio SmartCast Crave 360 Battery Replacement: étape 5, image 2 de 3 Vizio SmartCast Crave 360 Battery Replacement: étape 5, image 3 de 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
    Is it possible to fix motherboard?
    Beuran - Réponse
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: étape 6, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Battery: étape 6, image 2 de 2
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: étape 7, image 1 de 1
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: étape 8, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: étape 8, image 2 de 2
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: étape 9, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: étape 9, image 2 de 2
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: étape 10, image 1 de 1
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: étape 11, image 1 de 1
    • Remove the motherboard from the battery.
2 autres ont terminé cette réparation.
Pavani Lopez Leon
Membre depuis le 09/06/22
433 Réputation
3 tutoriels rédigés
Équipe
1 commentaire de tutoriel
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 59
Total : 1,688
