Xbox 360 Wireless Controller Triggers Replacement
Introduction
Passez à l'étape 1Fire away by replacing the triggers on your Xbox 360 Wireless Controller.
Ce dont vous avez besoin
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Outil utilisé dans cette étape :Tweezers$4.99
Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
Any recommendation on which set of Security Torx tools to use? I've already purchased 2 kits, one of those being sold as "Xbox controller tools" but the diameter of the head does not fit the hole on the controller and that's critical for the 2 screws on the bottom. The tools must obviously be thinner in diameter and long enough to get there.
How to open an XBOX 360 controller without a special screwdriver. http://www.instructables.com/id/How-to-o... Works perfectly.
A lot of thanks for your comment. It's very usefull
Echedey -
I picked up a handy torx key set from Auto Zone. Was about $10, no lose driver bits. has both sizes you need to repair the controller and the console. Here's the link:
It doesn't really matter which set of bits you by or what brand makes them, Torx bits (and the security versions of them) are generic & come in standardized sizes. You do not need a special "xbox" tool kit, you just need a size 8 torx security bit, no matter what brand makes the bit/kit. Those types of "specialty kits" are usually just collections of generic bits that you can buy at a hardware store in a regular bit set. The difference is that a general bit set will have bits for screws that a specific item doesn't have in it, whereas a specialty kit will only include bits for the types & sizes of fasteners used in the specified item.
BTW, with the smaller sizes of torx security bits you can try breaking off the little post in the middle with needlenose pliers or something else that can fit in the there. Even if the post doesn't break off cleanly, it's usually short enough to fit a regular (non security) torx bit in the slot.
Grasp the controller by the battery compartment and the headphone jack.
Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
Good information
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Remove the vibration motor from the other side of the controller using the same method previously described.
The opposite was true for the controller I just opened. It was the left motor counterweight (as you hold the controller normally) which had more weight. Perhaps it doesn't matter which goes where?
For anyone reading this in the future, it does matter. The way you had them originally is the correct way.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
What if you're having difficulty taking the logic board out?
Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
Push the trigger arm downward.
Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
Using the previously described technique, pry the housing on the right edge away from the trigger.
Rotate the trigger away from the logic board, past its housing.
Slide the trigger toward the right side of the logic board, and rotate it clockwise.
Remove the right trigger from the logic board.
This is a removal guide not a replacement guide. I need steps to putting the trigger back in now.
My trigger works by moving in and out but it is constantly either working or constantly not, when i press the home screen it switches between the two……help please
46 autres ont terminé cette réparation.
5 commentaires de tutoriel
use a small tag of double sided tape to hold the counterweights in when you rebuild or its nearly impossible to tip up the two halfs of the controller to fit them together. With the counterweight just slightly stuck into place with a tiny tag of double sided tape you can tip that half of the controller upside down to fit on top of the other half. Still awkward but do-able. Almost impossible otherwise.
If i leave out the vibrations things will it cause the problems tonthe board ??
These instructions were given in proper order and understanding
IMO this could have benefited from some instructions on how to get the triggers back on, cause it was quite a challenge.
The way I managed to do it, is you've got to reverse both step 11 and step 10 in one go, otherwise it would be impossible to get the trigger peg into the white arm (at least I couldn't figure out a way to do it): before reversing step 11, hold the white arm up and to same side you pushed it in the step 10, and then once you click it back into place, the peg would also go into the slot in the arm. For me it was easier to do for LT than RT - the latter too a few tries, so I would recommend doing LT first and then RT.
