Aller au contenu principal
Xbox 360 Wireless Controller Triggers Replacement
Brett Hartt
Brett Hartt et 8 autres contributeurs
Dernière mise à jour le August 22, 2022
15 - 40 minutes
Modérée
Tutoriel vedette
Fire away by replacing the triggers on your Xbox 360 Wireless Controller.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Xbox 360 Wireless Controller Triggers Replacement, Battery: étape 1, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement, Battery: étape 1, image 2 de 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Triggers Replacement, Rear Case: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Triggers Replacement: étape 3, image 1 de 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    Any recommendation on which set of Security Torx tools to use? I've already purchased 2 kits, one of those being sold as "Xbox controller tools" but the diameter of the head does not fit the hole on the controller and that's critical for the 2 screws on the bottom. The tools must obviously be thinner in diameter and long enough to get there.
    Arnie - Réponse
    How to open an XBOX 360 controller without a special screwdriver. http://www.instructables.com/id/How-to-o... Works perfectly.
    Louis - Réponse
    A lot of thanks for your comment. It's very usefull
    Echedey -
    I picked up a handy torx key set from Auto Zone. Was about $10, no lose driver bits. has both sizes you need to repair the controller and the console. Here's the link:
    http://www.autozone.com/autozone/accesso...
    FierDancr - Réponse
    It doesn't really matter which set of bits you by or what brand makes them, Torx bits (and the security versions of them) are generic & come in standardized sizes. You do not need a special "xbox" tool kit, you just need a size 8 torx security bit, no matter what brand makes the bit/kit. Those types of "specialty kits" are usually just collections of generic bits that you can buy at a hardware store in a regular bit set. The difference is that a general bit set will have bits for screws that a specific item doesn't have in it, whereas a specialty kit will only include bits for the types & sizes of fasteners used in the specified item.
    BTW, with the smaller sizes of torx security bits you can try breaking off the little post in the middle with needlenose pliers or something else that can fit in the there. Even if the post doesn't break off cleanly, it's usually short enough to fit a regular (non security) torx bit in the slot.
    Nerfbomb - Réponse
  4. Xbox 360 Wireless Controller Triggers Replacement: étape 4, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement: étape 4, image 2 de 2
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Triggers Replacement: étape 5, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement: étape 5, image 2 de 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Triggers Replacement: étape 6, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement: étape 6, image 2 de 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
    The RB / LB bar will fall away easily as you handle the upper case and logic board; just be prepared for it.
    knoxco - Réponse
    Good information
    mazvilaa640 - Réponse
  7. Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: étape 7, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: étape 7, image 2 de 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Triggers Replacement: étape 8, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement: étape 8, image 2 de 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
    The opposite was true for the controller I just opened. It was the left motor counterweight (as you hold the controller normally) which had more weight. Perhaps it doesn't matter which goes where?
    Bob S - Réponse
    For anyone reading this in the future, it does matter. The way you had them originally is the correct way.
    Yado Nada -
  9. Xbox 360 Wireless Controller Triggers Replacement, Logic Board: étape 9, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement, Logic Board: étape 9, image 2 de 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
    What if you're having difficulty taking the logic board out?
    Xander Uchida - Réponse
    In my experience with my controller, the logic board lifts out very easily, there are no tabs or fasteners holding it in.
    So, if you're having difficulty taking the logic board out, call a friend with average hand dexterity & motor skills to do it for you.
    Nerfbomb - Réponse
    If the controller is a bit old, the center plastic screw holder might have swollen and will need a little stenght to release the logic board.
    RoFixedIt - Réponse
  10. Xbox 360 Wireless Controller Triggers Replacement, Triggers: étape 10, image 1 de 3 Xbox 360 Wireless Controller Triggers Replacement, Triggers: étape 10, image 2 de 3 Xbox 360 Wireless Controller Triggers Replacement, Triggers: étape 10, image 3 de 3
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm downward.
  11. Xbox 360 Wireless Controller Triggers Replacement: étape 11, image 1 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 11, image 2 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 11, image 3 de 3
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  12. Xbox 360 Wireless Controller Triggers Replacement: étape 12, image 1 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 12, image 2 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 12, image 3 de 3
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  13. Xbox 360 Wireless Controller Triggers Replacement: étape 13, image 1 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 13, image 2 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 13, image 3 de 3
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
    This is a removal guide not a replacement guide. I need steps to putting the trigger back in now.
    Paul de Boer - Réponse
    My trigger works by moving in and out but it is constantly either working or constantly not, when i press the home screen it switches between the two……help please
    Daunte Mooney - Réponse
46 autres ont terminé cette réparation.
Brett Hartt
Membre depuis le 04/12/10
130 010 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 996 tutoriels rédigés
5 commentaires de tutoriel
use a small tag of double sided tape to hold the counterweights in when you rebuild or its nearly impossible to tip up the two halfs of the controller to fit them together. With the counterweight just slightly stuck into place with a tiny tag of double sided tape you can tip that half of the controller upside down to fit on top of the other half. Still awkward but do-able. Almost impossible otherwise.
iorigrif - Réponse
If i leave out the vibrations things will it cause the problems tonthe board ??
Michael Francis - Réponse
These instructions were given in proper order and understanding
Arthur Murray Doan - Réponse
IMO this could have benefited from some instructions on how to get the triggers back on, cause it was quite a challenge.
The way I managed to do it, is you've got to reverse both step 11 and step 10 in one go, otherwise it would be impossible to get the trigger peg into the white arm (at least I couldn't figure out a way to do it): before reversing step 11, hold the white arm up and to same side you pushed it in the step 10, and then once you click it back into place, the peg would also go into the slot in the arm. For me it was easier to do for LT than RT - the latter too a few tries, so I would recommend doing LT first and then RT.
Rathori - Réponse
Left trigger on xbox 360 wireless controler not working
Rog - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 59
30 derniers jours : 260
Total : 86,074
