Aller au contenu principal
iBook G4 14" 1.42 GHz Logic Board Replacement
Walter Galan
Walter Galan et 5 autres contributeurs
Dernière mise à jour le July 31, 2013
Aucune estimation
Difficile
The motherboard includes all ports except the DC-In board.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. iBook G4 14" 1.42 GHz Logic Board Replacement, Battery: étape 1, image 1 de 2 iBook G4 14" 1.42 GHz Logic Board Replacement, Battery: étape 1, image 2 de 2
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 14" 1.42 GHz Logic Board Replacement, Keyboard: étape 2, image 1 de 1
    • Pull the keyboard release tabs (shown in yellow) toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (shown in orange) 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 3, image 1 de 1
    • Loosen the four silver Phillips screws that secure the RAM shield.
    • These screws will not come out all the way. The screws are held captive to the RAM shield to prevent them from getting lost.
  4. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 4, image 1 de 1
    • Remove the RAM shield from the computer.
    • The four captive screws will come out with the RAM shield.
  5. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 5, image 1 de 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • When reassembling your iBook, make sure that you reconnect the keyboard cable before replacing the RAM shield.
  6. iBook G4 14" 1.42 GHz Logic Board Replacement, Lower Case: étape 6, image 1 de 1
    • Close the display and flip the computer over.
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The shorter screw is in the center.
    Oop's sorry on my earlier note I meant to say in step 2
    Keith - Réponse
    In my iBook G4 (Fr), there's no T8 Torx but nut driver.
    boninj - Réponse
  7. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 7, image 1 de 1
    • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
    Be careful, the rubber feet tend to jump out and get lost.
    Lakshmana - Réponse
  8. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 8, image 1 de 1
    • Remove the three newly-revealed Phillips screws.
    • One screw is underneath each bumper (three total).
  9. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 9, image 1 de 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  10. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 10, image 1 de 1
    • Remove the two Phillips screws on either side of the battery contacts.
  11. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 11, image 1 de 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push in the thin rims of the lower case surrounding the battery compartment, bending them past the tabs, and then lift up to free that corner of the lower case.
    This part scared me, never in an iFixIt guide have I seen a warning like "trying times are ahead".
    I used a plastic iPod opening tool and ran it around the seam in the same order pictured. I had the plastic off in less than a minute with almost no fuss.
    PohTayToez - Réponse
  12. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 12, image 1 de 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  13. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 13, image 1 de 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  14. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 14, image 1 de 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  15. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 15, image 1 de 1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  16. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 16, image 1 de 1
    • The front and sides of the lower case are now free.
    • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
    I found it easier and "safer" to use a spudge at the back as well (two on each side of the hinge)
    Paulix - Réponse
    Citation de Paulix :
    I did too. Thanks, Paulix.
    Ryan Cabanas - Réponse
  17. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 17, image 1 de 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  18. iBook G4 14" 1.42 GHz Logic Board Replacement, Bottom Shield: étape 18, image 1 de 1
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  19. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 19, image 1 de 1
    • Lift the bottom shield off.
  20. iBook G4 14" 1.42 GHz Logic Board Replacement, DC-In Board: étape 20, image 1 de 1
    • Remove the single Phillips screw securing the DC-In board.
    You might not need to remove the entire DC-In board and cable. This is removed because the DC-In jack blocks the upper case from being lifted off. I just removed the screw and pushed the board slightly in when removing the upper case to provide clearance. You may want to tape the board loosely in place when the screw is out to prevent it from falling out.
    georgie333 - Réponse
  21. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 21, image 1 de 1
    • Angle the DC-In board out of its compartment.
    • You may need to remove tape that secures the DC-In board cable to the case.
    You need to undo the adhesive halfway down the cable, so you can lift the DC board to angle it out correctly. beefybov
    beefybov - Réponse
    Citation de beefybov :
    Good call, beefybov.
  22. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 22, image 1 de 1
    • Lift the DC-In cable from the adhesive attaching it to the logic board.
  23. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 23, image 1 de 1
    • Disconnect the DC-In cable from the logic board.
    • Wiggling the connector parallel to the surface of the logic board while applying slight tension may aid in removal.
  24. iBook G4 14" 1.42 GHz Logic Board Replacement, Upper Case: étape 24, image 1 de 1
    • Remove the following 11 screws from the bottom of the computer:
    • Three 3 mm Phillips around the battery compartment.
    • Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
    • One 12 mm Phillips in the lower right corner.
    • Four 14.5 mm Phillips.
    On my model, both left-side screws are short and the (lower) right screw is the long one.
    axel - Réponse
    Sorry, this note should be for Step 25!
    axel - Réponse
  25. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 25, image 1 de 1
    • We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
    • Turn over the computer and open it.
    • Remove the 3 Phillips screws from the edges of the keyboard area.
    • The shorter screw goes in the lower left corner. The left corner is indicated by a blue "L" in the photograph and is on the right side.
    A soft cloth like the one you use to clean your screen with. Not a towel because of the static that might be built up in heavier fabrics.
    2myownbeat - Réponse
    The picture has the lower *right* screw marked as "L" -- but that's a mistake; the short screw is, as described, on the lower LEFT side.
    Peter King - Réponse
    On my computer, the screw in lower right marked "L" (long?) in the picture is M3x6mm and the other two are M3x3mm.
    donestabrook - Réponse
    Long screw goes into the right bottom corner - and the 3 mm on the left - at least at the computer I did.
    zhp - Réponse
    Yes, the LONG screw goes into the bottom RIGHT corner if the screen is facing you as it does when you're using the computer.
    Sugar Fish - Réponse
  26. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 26, image 1 de 1
    • Be especially careful while disconnecting the cables in the forthcoming steps. Never pull directly on the cables, but use a spudger to pry up the connector directly from its socket.
    • Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab.
    • Be careful while lifting the upper case, as its tabs are still hanging on the metal frame.
  27. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 27, image 1 de 1
    • The sockets attached to the motherboards of most iBooks are very weak and easily broken. Use extreme caution when pulling connectors out of their sockets.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails, carefully pry the connector from its socket.
    • Carefully disconnect the multicolored speaker cable from the logic board in the same fashion.
    use 2 tweezers instead: One with a fine tip to hold down the female socket and the other (or your fingernails) to pry up the male connector. That way you can better prevent the female socket to break off from the motherboard.
    Christian - Réponse
    This is a very tough one. I did break both the power cable and speaker cable off the motherboard, and was unable to separate the motherboard-side connectors from the cable-side connectors even after that. Fortunately, this iBook was already bricked.
  28. iBook G4 14" 1.42 GHz Logic Board Replacement, Top Shield: étape 28, image 1 de 1
    • Remove the following 16 screws:
    • Thirteen 3 mm Phillips.
    • One 3 mm Phillips.
    • Two 4 mm Phillips.
    • During reassembly, be sure to fit the screw near the left hinge through the loop in the display data cable, securing the cable to the upper case.
    on my model, the upper yellow screw and the orange screw were 3mm as well (red colour). So only the one right yellow screw was 4 mm.
    Paulix - Réponse
    On my computer there is only one 4mm screw. The leftmost bottom right. The others are 3 mm. It is actually written on the shield: M2X3 = 3 mm. M2X4 = 4 mm.
    Paulix - Réponse
    The little tabs on the shield that are intended to contact the metal on the ports and the optical drive had been flattened out on my iBook and were no longer in contact. I didn't notice this until I had installed the shield. Make sure the tabs are bent down a bit as to contact the ports and optical drive. This system looks like it replaced the foil tape on earlier models. Just my own observation.
    randy3833 - Réponse
  29. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 29, image 1 de 1
    • Lift the top shield up from the right side, minding the upper left corner which may catch on the metal framework.
  30. iBook G4 14" 1.42 GHz Logic Board Replacement, Modem: étape 30, image 1 de 1
    • Remove the two Phillips screws at the corners of the modem.
  31. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 31, image 1 de 2 iBook G4 14" 1.42 GHz Logic Board Replacement: étape 31, image 2 de 2
    • Use a spudger to pry the modem up from the end nearest the AirPort card to separate its connector from a socket on the logic board.
    • Be sure to pry only against the heat sink or the metal framework.
    • Use your hands to seperate the modem from the modem shield.
  32. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 32, image 1 de 1
    • Disconnect the RJ-11 cable from the end of the modem.
    • When replacing the modem, first make sure that both the microphone and display data cables are routed beneath where the modem lies.
  33. iBook G4 14" 1.42 GHz Logic Board Replacement, Heat Sink: étape 33, image 1 de 1
    • Remove the three 3 mm Phillips screws securing the AirPort card bracket to the metal framework.
    • Lift the AirPort card retaining bracket up and out of the computer.
  34. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 34, image 1 de 1
    • Remove the two 3 mm Phillips screws securing the AirPort card to the logic board.
  35. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 35, image 1 de 1
    • Using a spudger, pry up on the AirPort card from the end nearest the hard drive to separate the connector from its socket on the logic board.
    • Pry only between the metal framework and the AirPort card.
  36. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 36, image 1 de 1
    • De-route the AirPort antenna cables from above the heat sink and lay them aside.
    • It is not essential to disconnect the antenna cables from the AirPort card.
  37. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 37, image 1 de 1
    • Remove the following 9 screws and 2 nuts from the heat sink:
    • Four 3 mm Phillips from around the fan and the heat sink bracket. The bracket can also be removed at this point.
    • One 11.5 mm (left) and one 4.5 mm (right) Phillips from the plastic fingers of the hinge grill.
    • One 4.5 mm Phillips at the top right corner of the heat sink.
    • Two 6 mm Phillips on the lower left corner and face of the heat sink.
    • Two 4 mm screw nuts with attached springs from either side of the heat sink.
  38. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 38, image 1 de 1
    • It may be necessary to soften the thermal paste between the logic board and heat sink. You can soften the thermal compound using a hairdryer. Move the hairdryer back and forth over the ribbed metal section of the heat sink. At this point, the heat sink should come free easily.
    • If necessary, use a spudger to pry up the heat sink from the left side near the hard drive.
    • While lifting straight up on the hinge grill with your right hand, lift the heat sink with your left hand from the end nearest the hard drive and remove the heat sink assembly from the computer.
    • The hinge grill is held captive by the display assembly/clutch cover, and can only be partially raised.
  39. iBook G4 14" 1.42 GHz Logic Board Replacement, Logic Board: étape 39, image 1 de 1
    • Remove the two Phillips screws securing the white plastic fingers of the I/O bezel to the metal framework.
    • The longer screw goes into the longer finger, closer to the display.
  40. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 40, image 1 de 1
    • Lift up the left side of the computer and slide the I/O bezel away.
  41. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 41, image 1 de 1
    • Wedge a spudger between the RJ-11 board and the metal framework and slide the board to the left, off of the logic board.
  42. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 42, image 1 de 1
    • Use the black plastic loop to disconnect the display data cable from the logic board.
  43. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 43, image 1 de 2 iBook G4 14" 1.42 GHz Logic Board Replacement: étape 43, image 2 de 2
    • Remove the four 4mm Phillips screws securing the hard drive to the metal framework.
    • Carefully lift up the hard drive.
  44. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 44, image 1 de 1
    • The cable you're about to remove is very fragile.
    • Disconnect the microphone cable at the front of the computer, between the left side of the hard drive enclosure and the metal framework.
  45. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 45, image 1 de 1
    • Disconnect the Reed Switch board connector from the logic board.
  46. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 46, image 1 de 1
    • This is a diagram of the ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  47. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 47, image 1 de 1
    • Release the optical drive ribbon clamp as described above. Slide the optical drive ribbon out of its connector.
  48. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 48, image 1 de 2 iBook G4 14" 1.42 GHz Logic Board Replacement: étape 48, image 2 de 2
    • Remove the two 5mm Phillips screws securing the battery connector to the metal framework.
    • Lift the battery connector out of the metal framework and disconnect it from the logic board.
    • This connector requires considerable force to remove. We recommend wiggling the connector while applying tension to slowly "walk" the connector out of its socket.
  49. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 49, image 1 de 1
    • Remove the following 8 screws:
    • Eight 3.5 mm Phillips.
    • Two 3.5 mm Phillips near the sleep light connector.
    • One 3.5 mm Phillips with a large head in the lower left corner.
    • One 4.5 mm Phillips.
    • From top to bottom, disconnect the inverter, fan, and sleep light cables from the logic board.
    • When replacing the logic board, make sure that the inverter cable is not pinned under the logic board.
  50. iBook G4 14" 1.42 GHz Logic Board Replacement: étape 50, image 1 de 1
    • Lift the logic board up from the right side, and slide it up and out of the computer.
    • When replacing your logic board, be sure to transfer your old RAM chips to your new logic board.
    • Most 14" iBooks use thermally conductive pads rather than thermal paste to conduct heat from the processors to the heat sink. It is unlikely that these pads will fall off or become unusable during reinstallation. If so, be sure to apply a liberal amount of thermal paste to the surface of all processors before mounting the heat sink. This will avoid any damage from overheating.
20 autres ont terminé cette réparation.
Pièces jointes
1 commentaire de tutoriel
How to fix ibook startup with chime but black screen?
Jodi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 14
Total : 18,654
