Aller au contenu principal
iPhone 16 Plus Microphone Removal
Nick Schultz
Nick Schultz
Dernière mise à jour le January 10, 2025
Aucune estimation
Modérée
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
  1. iPhone 16 Plus Microphone Removal, Secure the screen: étape 1, image 1 de 3 iPhone 16 Plus Microphone Removal, Secure the screen: étape 1, image 2 de 3 iPhone 16 Plus Microphone Removal, Secure the screen: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next five steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the back glass, you need to secure the screen with tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the screen to secure it.
    • Make sure the tape is only securing the screen, and not the back glass.
  2. iPhone 16 Plus Microphone Removal, Secure an Anti-Clamp: étape 2, image 1 de 3 iPhone 16 Plus Microphone Removal, Secure an Anti-Clamp: étape 2, image 2 de 3 iPhone 16 Plus Microphone Removal, Secure an Anti-Clamp: étape 2, image 3 de 3
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the back glass facing up, slide the arms over the right edge of your phone, with one suction cup on the back glass and the other on the screen. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  3. iPhone 16 Plus Microphone Removal: étape 3, image 1 de 3 iPhone 16 Plus Microphone Removal: étape 3, image 2 de 3 iPhone 16 Plus Microphone Removal: étape 3, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may warm up the suction cups to help them stick.
  4. iPhone 16 Plus Microphone Removal, Heat the bottom edge: étape 4, image 1 de 2 iPhone 16 Plus Microphone Removal, Heat the bottom edge: étape 4, image 2 de 2
    • Heat your iOpener and apply it to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the back glass and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp do the work for you, repeating this process as necessary.
  5. iPhone 16 Plus Microphone Removal, Insert an opening pick: étape 5, image 1 de 3 iPhone 16 Plus Microphone Removal, Insert an opening pick: étape 5, image 2 de 3 iPhone 16 Plus Microphone Removal, Insert an opening pick: étape 5, image 3 de 3
    • Insert the tip of an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  6. iPhone 16 Plus Microphone Removal, Heat the bottom edge: étape 6, image 1 de 2 iPhone 16 Plus Microphone Removal, Heat the bottom edge: étape 6, image 2 de 2
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
  7. iPhone 16 Plus Microphone Removal, Insert an opening pick: étape 7, image 1 de 3 iPhone 16 Plus Microphone Removal, Insert an opening pick: étape 7, image 2 de 3 iPhone 16 Plus Microphone Removal, Insert an opening pick: étape 7, image 3 de 3
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
  8. iPhone 16 Plus Microphone Removal, Back glass information: étape 8, image 1 de 2 iPhone 16 Plus Microphone Removal, Back glass information: étape 8, image 2 de 2
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  9. iPhone 16 Plus Microphone Removal, Separate the bottom edge adhesive: étape 9, image 1 de 3 iPhone 16 Plus Microphone Removal, Separate the bottom edge adhesive: étape 9, image 2 de 3 iPhone 16 Plus Microphone Removal, Separate the bottom edge adhesive: étape 9, image 3 de 3
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contacts.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
  10. iPhone 16 Plus Microphone Removal, Heat the right edge: étape 10, image 1 de 2 iPhone 16 Plus Microphone Removal, Heat the right edge: étape 10, image 2 de 2
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
  11. iPhone 16 Plus Microphone Removal, Separate the bottom right corner adhesive: étape 11, image 1 de 3 iPhone 16 Plus Microphone Removal, Separate the bottom right corner adhesive: étape 11, image 2 de 3 iPhone 16 Plus Microphone Removal, Separate the bottom right corner adhesive: étape 11, image 3 de 3
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the spring contacts and ribbon cable.
    • Slide your pick around the bottom right corner and slide it halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  12. iPhone 16 Plus Microphone Removal, Heat the left edge: étape 12, image 1 de 2 iPhone 16 Plus Microphone Removal, Heat the left edge: étape 12, image 2 de 2
  13. iPhone 16 Plus Microphone Removal, Separate the left edge adhesive: étape 13, image 1 de 3 iPhone 16 Plus Microphone Removal, Separate the left edge adhesive: étape 13, image 2 de 3 iPhone 16 Plus Microphone Removal, Separate the left edge adhesive: étape 13, image 3 de 3
    • Don't insert your pick deeper than 5 mm along the left edge to avoid damaging the spring contact.
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  14. iPhone 16 Plus Microphone Removal, Heat the top edge: étape 14, image 1 de 2 iPhone 16 Plus Microphone Removal, Heat the top edge: étape 14, image 2 de 2
    • Apply a heated iOpener to the top edge of the back glass, angled to include the volume buttons, for two minutes.
    • When using a hair dryer or heat gun, heat until it's hot to the touch.
  15. iPhone 16 Plus Microphone Removal, Separate the top edge adhesive: étape 15, image 1 de 3 iPhone 16 Plus Microphone Removal, Separate the top edge adhesive: étape 15, image 2 de 3 iPhone 16 Plus Microphone Removal, Separate the top edge adhesive: étape 15, image 3 de 3
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You should hear and feel clicks as the top two clips release.
  16. iPhone 16 Plus Microphone Removal, Swing open the back glass: étape 16, image 1 de 2 iPhone 16 Plus Microphone Removal, Swing open the back glass: étape 16, image 2 de 2
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
  17. iPhone 16 Plus Microphone Removal, Unfasten the middle connector cover: étape 17, image 1 de 2 iPhone 16 Plus Microphone Removal, Unfasten the middle connector cover: étape 17, image 2 de 2
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the middle connector cover.
  18. iPhone 16 Plus Microphone Removal, Remove the middle connector cover: étape 18, image 1 de 2 iPhone 16 Plus Microphone Removal, Remove the middle connector cover: étape 18, image 2 de 2
    • Be careful not to dent or puncture the battery during this step.
    • Use blunt-nose tweezers or your fingers to slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
    • During reassembly, align the hooks over their slots on the logic board. Then, press the cover down and slide it towards the right edge to re-engage the hooks.
  19. iPhone 16 Plus Microphone Removal, Disconnect the battery: étape 19, image 1 de 3 iPhone 16 Plus Microphone Removal, Disconnect the battery: étape 19, image 2 de 3 iPhone 16 Plus Microphone Removal, Disconnect the battery: étape 19, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip or the flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  20. iPhone 16 Plus Microphone Removal, Disconnect the wireless charger: étape 20, image 1 de 2 iPhone 16 Plus Microphone Removal, Disconnect the wireless charger: étape 20, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  21. iPhone 16 Plus Microphone Removal, Remove the back glass: étape 21, image 1 de 2 iPhone 16 Plus Microphone Removal, Remove the back glass: étape 21, image 2 de 2
    • Lift the back glass off the frame and remove it.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass (before replacing the adhesive), power on your phone, and make sure it works as expected. Power it back down, disconnect the battery, and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  22. iPhone 16 Plus Microphone Removal, Remove the Taptic Engine bracket screws: étape 22, image 1 de 2 iPhone 16 Plus Microphone Removal, Remove the Taptic Engine bracket screws: étape 22, image 2 de 2
    • Use a Phillips screwdriver to remove the three screws securing the Taptic Engine bracket:
    • Two 1.9 mm‑long screws
    • One 2.1 mm‑long screw
  23. iPhone 16 Plus Microphone Removal: étape 23, image 1 de 2 iPhone 16 Plus Microphone Removal: étape 23, image 2 de 2
    • Use tweezers or your fingers to remove the Taptic Engine bracket.
  24. iPhone 16 Plus Microphone Removal, Disconnect the Taptic Engine: étape 24, image 1 de 2 iPhone 16 Plus Microphone Removal, Disconnect the Taptic Engine: étape 24, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the Taptic Engine press connector.
  25. iPhone 16 Plus Microphone Removal, Remove the Taptic Engine screw: étape 25, image 1 de 2 iPhone 16 Plus Microphone Removal, Remove the Taptic Engine screw: étape 25, image 2 de 2
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the Taptic Engine.
  26. iPhone 16 Plus Microphone Removal, Remove the Taptic Engine: étape 26, image 1 de 2 iPhone 16 Plus Microphone Removal, Remove the Taptic Engine: étape 26, image 2 de 2
    • Use blunt-nose tweezers or your fingers to pick up and remove the Taptic Engine.
  27. iPhone 16 Plus Microphone Removal, Remove the loudspeaker screws: étape 27, image 1 de 2 iPhone 16 Plus Microphone Removal, Remove the loudspeaker screws: étape 27, image 2 de 2
    Standoff Screwdriver for iPhones
    $5.49
    • Be careful not to puncture or dent the battery with your screwdriver.
    • Use your Phillips screwdriver to remove four of the screws securing the loudspeaker:
    • Three 1.5 mm-long screws
    • One 3.0 mm-long screw
    • Use your tri-point Y000 screwdriver to remove the 1.3 mm-long screw securing a grounding contact and the loudspeaker.
    • Use your standoff screwdriver to remove the 3.4 mm-long screw securing the loudspeaker.
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
  28. iPhone 16 Plus Microphone Removal, Remove the loudspeaker: étape 28, image 1 de 2 iPhone 16 Plus Microphone Removal, Remove the loudspeaker: étape 28, image 2 de 2
    • Grab the loudspeaker and remove it.
  29. iPhone 16 Plus Microphone Removal, Disconnect the microphone: étape 29, image 1 de 2 iPhone 16 Plus Microphone Removal, Disconnect the microphone: étape 29, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the microphone's press connector.
    • Don't pry against the battery, it could catch fire if damaged.
  30. iPhone 16 Plus Microphone Removal, Remove the microphone screws: étape 30, image 1 de 2 iPhone 16 Plus Microphone Removal, Remove the microphone screws: étape 30, image 2 de 2
    • Remove the four screws securing the microphone:
    • One 3.3 mm‑long standoff screw
    • One 1.3 mm‑long tri-point Y000 screw
    • One 1.5 mm‑long Phillips screw
    • One 1.3 mm‑long Phillips screw
  31. iPhone 16 Plus Microphone Removal, Remove the microphone: étape 31, image 1 de 3 iPhone 16 Plus Microphone Removal, Remove the microphone: étape 31, image 2 de 3 iPhone 16 Plus Microphone Removal, Remove the microphone: étape 31, image 3 de 3
    Tesa 61395 Tape
    $6.99
    • The microphone is held in place by strong adhesive to the bottom edge of the phone.
    • Insert the flat end of a spudger under the top edge of the microphone and pry up until you can grab it with your fingers.
    • If the microphone does not budge, try adding a little bit of heat using an iOpener, hair dryer, or heat gun. Only heat it it's slightly hot to touch, as the battery is susceptible to heat damage.
    • Peel the microphone from the adhesive securing it to the frame and remove it.
    • During reassembly, if your replacement part doesn't include adhesive, use thin, double-sided tape instead. Make sure it doesn't block the sound cutouts during installation.
Nick Schultz
Membre depuis le 03/24/24
15 772 Réputation
87 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 418 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 17
