Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Traduction de l’étape 1
Étape 1
You will need to use a Phillips #00 screwdriver.
Remove the four screws located at the corners beneath the battery.
Detach the back case from the phone.
- | [* black] Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone. |
+ | [* black] You will need to use a Phillips #00 screwdriver. |
+ | [* red] Remove the four screws located at the corners beneath the battery. |
+ | [* orange] Detach the back case from the phone. |
