Aller au contenu principal
Remplacement des boutons L et R du PowerA Enhanced Wireless Controller
Anglais
Français
Conditions préalables au tutoriel
Tous les tutoriels prérequis doivent être traduits avant que cette traduction soit considérée comme complète.
Remplacement de la carte mère du PowerA Enhanced Wireless Controller
Informations sur le tutoriel
= Terminé = Incomplet
    This guide will show you how to access and replace the L and R buttons of your PowerA Enhanced Wireless Controller. If you need to clean any residue from the L and R button area, removing them will help you do so.
    If you've been experiencing issues with the functionality of your L and R buttons while using your PowerA Enhanced Wireless Controller for Nintendo Switch, you're not alone. These buttons are crucial to the operation of the controller and can often become less responsive over time due to wear and tear. This guide will walk you through the necessary steps to access and replace or clean these buttons, restoring your controller to peak performance.
    This repair will address common issues such as marginal response of the L and R buttons, L and R buttons sticking due to dust or residue build up and/or physical damage on the L and R buttons.
    Before beginning the repair process, it's important to remove the batteries from your controller to ensure your safety during the repair and prevent any potential issues with the motherboard. Step 1 of this guide will show you how to access the battery compartment.
      Étapes du tutoriel
      Étape 1
      Soulevez les deux loquets blancs à l'aide de l'outil d'ouverture iFixit.
      Étape 2
      Pressez les boutons avec une pince à épiler en caoutchouc et enfoncez-les.
