Aller au contenu principal
Changement écran Nokia G22
Anglais
Français
Traduction de l’étape 8
Étape 8
Nokia G22 Screen Assembly Replacement, Only the screen assembly remains: étape 0, image 1 de 1
  • Only the screen assembly remains.
  • During reassembly, compare your new replacement assembly to the original part:
  • If your part comes with battery adhesive pre-installed, remove its plastic liners before continuing to the previous step.
  • If your part has no battery adhesive, remove the clear liner on the pre-cut battery adhesive and apply the sticky section to the battery well. Remove the opaque liner before continuing to the previous step.
  • If you're reusing your original battery, carefully inspect it for any signs of physical damage. If it's bent, creased, dented or scratched, replace it with a new battery. Installing a damaged battery is a safety hazard.
Il ne reste plus que l'ensemble écran.
Comparez votre ensemble écran Nokia G22 de remplacement à la pièce d'origine. Il vous faudra peut-être transférer d'éventuels composants restants ou retirer des films adhésifs avant de commencer le remontage.
Si vous réutilisez votre batterie d'origine, inspectez-la soigneusement pour détecter tout signe de dommage physique. Si elle est déformée, plissée, bosselée ou rayée, remplacez-la par une batterie neuve. Installer une batterie endommagée est très dangereux.
[title] Only the screen assembly remains
[* black] Only the screen assembly remains.
-[* icon_reminder] Compare your new replacement assembly to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
+[* icon_reminder] During reassembly, compare your new replacement assembly to the original part:
+ [* black] If your part comes with battery adhesive pre-installed, remove its plastic liners before continuing to the previous step.
+ [* black] If your part has no battery adhesive, remove the clear liner on the pre-cut battery adhesive and apply the sticky section to the battery well. Remove the opaque liner before continuing to the previous step.
[* icon_caution] If you're reusing your original battery, carefully inspect it for any signs of physical damage. If it's [link|https://guide-images.cdn.ifixit.com/igi/CmJ6ZiW1sIQZLjoC.full|bent, creased|new_window=true], [link|https://guide-images.cdn.ifixit.com/igi/OrnT4eml322MUDj1.full|dented or scratched|new_window=true], replace it with a new battery. ***Installing a damaged battery is a safety hazard.***
