Aller au contenu principal
L'OP-1 est un outil de traitement de musique, intégrant synthétiseur, échantillonneur, enregistreur multipiste, boîte à rythme, mélangeur et contrôleur
Why does the lower half of my keyboard not trigger?
Hello. The lower half of my keyboard on op1 is not working. Also my USB port has pushed through housing. Does anyone know how I can fix it or where I can have it fixed? Thank you
Chris
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Non-working, or intermittently working keys are most likely due to a glitch in the connection between the OP-1 Keyboard and the rest of the unit. If you want to try to fix this yourself then we suggest that you follow this guide. Basically start by removing the keys to uncover the screws, unscrew and lift the keyboard module, then remove and reinsert the connectors. Sometimes this resolves the issue, at least temporary, and a keyboard replacement is not needed. Good luck!
Please note: You will void any remaining warranty by doing this.
Image Replace the Teenage Engineering OP-1 keyboard module and fix an unresponsive key. This part includes 12 loose keys.
Produit
OP-1 Keyboard
$119.99
Indice 0
Pièces et outils connexes
Tous les produits
Ajouter une réponse
Chris leidy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 613
