Left headlight low beam inop
Where is the fuse or relay for the left low beam head light located on a 2005 Nissan altimal 3.5. No power at bulb
Accédez rapidement aux tutoriels, aux pièces et aux réponses correspondant à vos appareils
Hi @trobi ,
Here are two images taken from the service manual -lighting system LT for a 2005 Nissan Altima describing and showing the fuses and wiring details for the headlights.
(click on images to enlarge for better viewing)
IPDM E/R means Intelligent Power Distribution module Engine Room.
If fuse #45 appears to be OK you need to check that there is power available at terminal #30 of the IPDM E/R harness connector (remember to turn on the headlight switch - low beam ;-)
If there is power available there, then there is a problem with the harness to the light.
If there is no power available there according to the manual on p.LT-23 the IPDM E/R module needs to be replaced.
The fuse panel is next to the driver’s left knee. There should be legends for all fuses in that panel or on the lid.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 9,652
