Aller au contenu principal
En juin 2017, Apple met à jour le MacBook Air 13" avec un nouveau processeur Intel Core i5 Broadwell, ce qui donne une légère augmentation des performances et de l'autonomie de la batterie.
20 questions Voir tout
Why is my usb port not working
This has been happening for a while (can't remember when it started), but on my MBA 2017, one of the two USB ports won't work, the one next to the MagSafe Connector.
All USB cables/flash dives only go in half way, all but 1 flash drive goes in and connects.
Other USB port is fine with all cables tried is OK … I've looked into the effected USB port to see if any dust in there, but I couldn't see anything.
If I hold some USB cables I do get a connection, so I don't think it’s not port issue ‘per-say’. Just cables won't go all the way in. (e.g my phone will argue of I hold the cable to get connection, but external hard drive has enough power to spin up, but not to be registered on Mac.)
Any suggestions?
usb drive work:
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
The easiest thing here is just replace the connector! As it turns out this one is very easy to do. MacBook Air 13" (Mid 2013-2017) I/O Board and here’s the guide Remplacement de la carte E/S du MacBook Air 13" début 2015
Image Replace a used I/O board compatible with the Mid 2013 to 2017 MacBook Air 13" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports.
Produit
$79.99
Indice 1
Ajouter une réponse
na na sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 111
