Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,4 GHz, 2,7 GHz ou 2,8 GHz (Turbo Boost jusqu'à 3,8 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
Graphics card not showing up causing no backlight
Hello,
a little while ago my Earl 2013 MBP the back light stopped working upon investigation I believe it’s a 1.5GB Nvidia 660m doesn’t show up at all in the system there is no kernal panics the only issue is the backlight it’s temperamental
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires:
This series came in two configs with and without a discreet GPU, AMD GPU (DG) vs intergraded Intel graphics engine only (IG)
IG Models: MacBookPro11,2
DG Models: MacBookPro11,3
So lets not get lost on the different graphics this series offers as that doesn't involve the backlight.
par
Thank you Dan for getting back to me I will check it in a moment
par
Ajouter un commentaire
1 Réponse
Most likely you have some corrosion damage either on the logic board display connector
Or within the displays connection (very difficult to get to)
Follow this guide to at least checkout your logic board connection MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement Follow Steps 1 through 4 to disconnect the battery, then jump down to Step 11. How does the contacts and solder joints look? Post some clear pics if you’ve not sure Ajout d'images à une question existante.
Image MacBook Pro 15" Retina Display Early 2013 Display Assembly
Tutoriel
Difficulté :
Difficile
1 - 2 hours
Image iFixit
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Indice 0
2 commentaires:
Hey Dan I have done extensive checking for corrosion and there is none as for the other connector it’s all secure and no problems there
par
@peach production - Plug in an external monitor with either the HDMI or Thunderbolt ports. Is that display working without a problem?
par
Ajouter une réponse
peach production sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 89
