Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz) ou 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz) avec 6 Mo de cache L3 partagé.
Replaced battery, magsafe light not on, battery not charging
Replaced the battery after the old one was seeming to expand.
When I first turned on the computer after the battery intallation the battery showed 100%, then it instantly went down to 25% which it has been ever since. The mag-safe light is not turning on and “Battery not Charging” on battery info. I am uploading the coconut battery report if that helps. Thank you for your help!
Update (01/07/2022)
Thank you very much for your reply, I was just going to update that I moved the charger to another plug and it started charging, but now has gone up to 39% and although at the time the menu stated that the battery was charging now again it is stuck at 39% stating that the battery is not charging… could it be a charger issue?
I am attaching the new coconut Battery report.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Sadly your charging logic on the main logic board has a problem. Other than making sure the MagSafe port contacts and insulator area are clean so the power is getting in (the center one-wire comm connection is working here) there is little you can do here without fixing the issue which is likely a burnt comparator resistor or two.
Here’s a good reference: How cheap eBay batteries DESTROY Macbook logic boards!
Indice 1
2 commentaires:
I have not used an ebay battery though, I bought one here. Could the burnt comparator resistor also happen by a faulty charger cable i.e. when the outer tube has split?
par
@morefaith - Yes! The charger can short out the power to one-wire lines. Please get a REAL Apple unit directly from Apple Apple 85W MagSafe 2 Power Adapter (for MacBook Pro with Retina display)
Your issue is not the battery.
par
MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement
Indice 0
Ajouter une réponse
Marina S sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 85
