Aller au contenu principal
Toshiba Satellite P205-S8811 laptop. This laptop boasts a full keypad, along with a 17' display.
1 questions Voir tout
Where should I locate cmos battery
I want to replace cmos battery in my toshiba satellite P205-S8811
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Toshiba laptops are a wildcard. They have used "buried" primary batteries (must fully disassemble the notebook), and some are easy (such as my like mom's old L755 (this was cheap junk, I'm glad it kicked the bucket) where it was under the RAM door. Others (Read: low-cost new, often "disposable"; these were unserviceable by design) use the soldered CMOS battery :-(. It makes CMOS battery repairs a complete PITA.
This variation is why the expert response is this:
  • Avoid all Toshibas that are new enough to have this garbage (how I do it)
    • The exception is vintage ones in nice condition - think anything up to Pentium II and MAYBE PIII. PIV and up are "modern" or are in the process of cooking their guts due to high CPU temperatures (or are already dead).
  • Look up the motherboard and base it on that (not always possible to see both sides, but if it's not visible on the bottom, it's often soldered)
  • Negotiation if it is (I don't bother)
This one has a soldered CMOS battery -- not an easy DIY job! If you want to do this, you need a tabbed battery (or a battery and spot welder to transfer the tabs), and make sure it isn't rechargeable. On some of these, the cell is "rechargeable" rather than a "primary" battery like the socketed ones. If the motherboard expects a rechargeable one and it's replaced with a non-rechargeable primary, it will explode. This was a routine issue with Toshiba for years.
Indice 2
2 commentaires:
@nick ,
Wouldn't recommend a welder.
The battery model number should be printed on the battery, so it should be easy to find using that information.
Cheers
par
@jayeff Yeah her Toshiba with the DMCA abuse years ago ruined Toshiba for me. I despised that thing, and was quick to dump it when she was willing to part with it. In hindsight, yeah I thought mentioning Toshiba's nonsense would clarify throwing her old laptop out was a welcome day would suffice :/.
She still prefers "consumer grade" for the warranty, but she's seen what a proper business class laptop is built like... Aluminum chassis all-around (not mixed), magnesium or a mix. In some cases, CFRP and magnesium like some of the really nice Dells before they started soldering the 7000 series components down to the wireless card. If they bring the magnesium/CFRP chassis to the 5000 series as a premium option, I'd be happy with that compromise.
Sadly, we're still stuck with these "unserviceable CMOS battery" laptops because people bought them without checking, and Toshiba loved the soldered tabbed cells on a lot of the cheap laptops, for years. Unless the new owner is willing to pick up a soldering iron, these will enter the waste stream as the coin cells die. Ugh, I hate that Toshiba ever decided to freaking solder a WEAR ITEM to the motherboard. Sockets are what? $1-2 in small amounts, so it would be fractions of a cent to make the battery serviceable. You could modify these with a CR2032 socket and 2 wires (tack down the socket in an area where the board and palmrest won't disagree), but it doesn't change the fact that you need to fix the unserviceable design (and in many cases, the laptops aren't worth the trouble).
par
Ajouter une réponse
Tech Jass sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 38
Total : 730
