Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,4 GHz, 2,7 GHz ou 2,8 GHz (Turbo Boost jusqu'à 3,8 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
Display dead after battery replacement
I followed these instructions with a new iFixit battery for my early-2013 MBP. It was working fine (other than the battery not holding charge) when I started (it's all backed up, that's not the issue, I just want to be able to use this old friend).
After reassembly, I connected magsafe to AC, and the machine immediately chimed. However, the screen remains completely black.
Here's what I know: on connection, the magsafe charging led is green, then turns orange; the CapsLock led is active; I can power down (no CapsLock led) and back on (chimes, CapsLock led working) with the power button; I've reset SMC and PRAM with the button + powercycle combinations; there's no signal on the hdmi port (the monitor I connected to does not see a signal); I've disassembled and reinserted the display data cable twice (Step 29 in attached instructions).
Does anyone have a suggestion about something I could try next? Thanks in advance -- wylbur.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
4 commentaires
Using a flashlight pressed against the screen at a sharp angle are you able to see a faint image of your desktop and its icons?
par
Thanks for this idea.
I just checked 2 different flashlights, and no, the screen has nothing on it (it would be a login screen I think but I can't see a colored background or anything else).
par
What happens if you disconnect the battery and try to power it on with just the MagSafe charger plugged in?
par
@Duck great question! I will need to get back to my shop to test this, I hope to have an answer in 24h.
par
Ajouter un commentaire
1 Réponse
Solution retenue
At this point I would re-connect your old battery to see if that altered things.
Indice 0
1 commentaire:
Ah, regrettably removing the battery was destructive. As I detached the battery cells from the adhesive (even with a liberal use of the solvent) connecting them to the chassis, I wrecked their cables. Alas, this might not have been a successful repair. Thanks for your thoughts.
par
Ajouter une réponse
Patrick Ball sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 116
