Aller au contenu principal
A point and shoot camera in the Cyber-shot series, released in 2010.
9 questions Voir tout
White line at the center of the LCD
The LCD has a thin white line at the center of the screen. Factory reset did not fix the issue. It might have been dropped.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @ashrafhuss96118
Try taking some pictures and then download them to a computer and check if there's a white line showing in the picture as well.
If not then most probably there are problem in the LCD screen.
If there is then it could be a problem in the CCD sensor.
Here's the service manual for the camera.
Go to p.7/12 to view the disassembly procedure.
On p.8/12 it shows how to remove the LCD screen. Search online for 1-811-083-11, to find suppliers for the LCD screen that suit you best. This is the Sony part number (part #54) for the LCD screen.
On p.10/12 it shows the CCD assembly see part #153.
Indice 1
2 commentaires:
Thank you Jayeff. I'll check the CMOS sensor first and then if the sensor looks good, will check the LCD connector ribbon.
par
@ashrafhuss96118
Doesn't seem like a LCD ribbon problem but time will tell. More likely if the CCD sensor tests OK i.e. good pictures seen when downloaded and viewed then the LCD screen itself is the problem i.e. internal to the screen.
par
Ajouter une réponse
Ashraf Hussain sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 8
Total : 51
