Aller au contenu principal
Beats Pill XL Battery Replacement
Nolan
Nolan et 3 autres contributeurs
Dernière mise à jour le July 3, 2018
10 - 15 minutes
Facile
Involves opening up the Beats Pill XL and removing the X-clamps holding the batteries in place. Disconnect the battery from the logic board and remove it from the device. You'll need to disconnect a ribbon cable to easily remove the battery.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Beats Pill XL Battery Replacement, Case: étape 1, image 1 de 2 Beats Pill XL Battery Replacement, Case: étape 1, image 2 de 2
    • Using a plastic opening tool, pry the casing from the rest of the device.
    • Pry all the way around the edge and then pull apart.
    • It should be relatively easy, to pull apart. Don't be afraid to apply a necessary force.
  2. Beats Pill XL Battery Replacement: étape 2, image 1 de 1
    • Using your thumb, remove the 8 rubber plugs in order to get to the screws.
    • Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
    • In the picture provided, we labeled four of them on one side of the Beats Pill XL. The other four are symmetrical to these four on the other side of the device.
  3. Beats Pill XL Battery Replacement: étape 3, image 1 de 2 Beats Pill XL Battery Replacement: étape 3, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
  4. Beats Pill XL Battery Replacement: étape 4, image 1 de 2 Beats Pill XL Battery Replacement: étape 4, image 2 de 2
    • Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Separate at a slow constant force to avoid damage to the ribbon cables.
  5. Beats Pill XL Battery Replacement: étape 5, image 1 de 2 Beats Pill XL Battery Replacement: étape 5, image 2 de 2
    • Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
    • Never pull the cables by the cord, as this could cause damage to the cables and/or motherboard. Always disconnect the cables from the base by the motherboard.
    Hola amigos y amigas como estan me pueden ayudar como puedo conseguier la placa del beatspill esta q esta aki xf urgente soy de Ecuador ciudad manta
    Stalin Salavarrialoor - Réponse
  6. Beats Pill XL Battery Replacement: étape 6, image 1 de 2 Beats Pill XL Battery Replacement: étape 6, image 2 de 2
    • Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
    • Even though there are two batteries, there is only one cable connecting the two to the motherboard.
    Hola nesecito esa placa xf alguien q me diga como la consigo
    Ye bluetooth order krna hai
    Mivi-s32-v1.0 - Réponse
  7. Beats Pill XL Battery Replacement, Battery: étape 7, image 1 de 3 Beats Pill XL Battery Replacement, Battery: étape 7, image 2 de 3 Beats Pill XL Battery Replacement, Battery: étape 7, image 3 de 3
    • Using a Phillips #2 screwdriver, remove the 8 (11mm pan head Phillips #2) screws holding down the the X-clamps.
    • Remove the X-clamps by simply lifting upwards.
    • Save the 8 (11mm pan head Phillips #2) screws for reassembly as these are easy to misplace.
  8. Beats Pill XL Battery Replacement: étape 8, image 1 de 2 Beats Pill XL Battery Replacement: étape 8, image 2 de 2
    • Gently pull up on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
  9. Beats Pill XL Battery Replacement: étape 9, image 1 de 2 Beats Pill XL Battery Replacement: étape 9, image 2 de 2
    • Remove the padded sticker holding down the ribbon cable to one of the batteries.
    • Use a slow constant force, as ribbon cables are fragile and could tare.
    Use a slow constant force, as ribbon cables are fragile and could tear.
    Dan - Réponse
  10. Beats Pill XL Battery Replacement: étape 10, image 1 de 2 Beats Pill XL Battery Replacement: étape 10, image 2 de 2
    • Lift straight up from the casing to remove each batteries from their tight spaces.
22 autres ont terminé cette réparation.
Nolan
Membre depuis le 03/11/15
882 Réputation
2 tutoriels rédigés
Équipe
Colorado Springs, Team 9-2, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 9-2, Panko Spring 2015
UCCS-PANKO-S15S9G2
3 membres
7 tutoriels rédigés
7 commentaires de tutoriel
como saber se o problema da minha caixa e a bateria, ela nao esta carregando nem liga, a bateria porem nao esta dando 12v medicao, uma por sinal esta com carga negativa. no aguardo
marcosallexandre - Réponse
Where can i buy these replacement batteries?
Edgar Zuniga - Réponse
From here you can find a replacement battery
http://www.witpow.com/shopdvr/product/4/...
lisi -
i think it's better to change a battery than buy a new one. And i was luck to find a replacement battery.lol
Jailene -
This was helpful, however, it is just a reference…a lot more difficult than explained here…Take your time and take photos along the way…The battery is found on Amazon…the included tools a joke…be careful…it takes time…stoked my speaker works again…https://www.amazon.com/gp/product/B073FB...
FREISme - Réponse
super !! merci , impeccable , super simple … take care !
stev.roma - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 135
Total : 29,546
