Beats Pill XL Battery Replacement
Introduction
Passez à l'étape 1Involves opening up the Beats Pill XL and removing the X-clamps holding the batteries in place. Disconnect the battery from the logic board and remove it from the device. You'll need to disconnect a ribbon cable to easily remove the battery.
Ce dont vous avez besoin
Using a plastic opening tool, pry the casing from the rest of the device.
Pry all the way around the edge and then pull apart.
Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
Hola amigos y amigas como estan me pueden ayudar como puedo conseguier la placa del beatspill esta q esta aki xf urgente soy de Ecuador ciudad manta
Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
Hola nesecito esa placa xf alguien q me diga como la consigo
Ye bluetooth order krna hai
Using a Phillips #2 screwdriver, remove the 8 (11mm pan head Phillips #2) screws holding down the the X-clamps.
Remove the X-clamps by simply lifting upwards.
22 autres ont terminé cette réparation.
7 commentaires de tutoriel
como saber se o problema da minha caixa e a bateria, ela nao esta carregando nem liga, a bateria porem nao esta dando 12v medicao, uma por sinal esta com carga negativa. no aguardo
Where can i buy these replacement batteries?
From here you can find a replacement battery
lisi -
It's under recall https://www.apple.com/support/beats-pill...
i think it's better to change a battery than buy a new one. And i was luck to find a replacement battery.lol
Jailene -
This was helpful, however, it is just a reference…a lot more difficult than explained here…Take your time and take photos along the way…The battery is found on Amazon…the included tools a joke…be careful…it takes time…stoked my speaker works again…https://www.amazon.com/gp/product/B073FB...
