Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Introduction
Suivez ce tutoriel pour remplacer l'ensemble caméra arrière dans votre iPhone 14 Pro Max.
Ce tutoriel a été créé en utilisant le modèle A2894 (international). Si vous réparez un autre modèle d'iPhone 14 Pro Max, il peut y avoir quelques différences visuelles, mais la procédure devrait être la même.
Vous aurez besoin d'un adhésif de remplacement pour fixer l'écran lors du remontage de l'appareil. Votre appareil fonctionnera normalement, mais perdra très probablement son indice de protection IP (Ingress Protection).
Ce dont vous avez besoin
Éteignez votre iPhone avant de commencer le démontage.
Retirez les deux vis Pentalobe P2 d'une longueur de 6,8 mm en bas de l'iPhone.
Mesurez 3 mm à partir de la pointe et tracez une ligne sur le médiator avec un marqueur permanent.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
Recouvrez l'écran de bandes de ruban adhésif, qui se chevauchent, jusqu'à ce que toute la surface soit couverte.
Si la ventouse n'adhère pas au cours des étapes suivantes, pliez un morceau de ruban adhésif épais (du ruban adhésif toilé p.e.) pour former une poignée et soulevez l'écran de cette façon.
Outil utilisé dans cette étape :Clampy - Anti-Clamp$24.95
Tirez la poignée bleue vers l'arrière pour débloquer les bras de l'Anti-Clamp.
Insérez le côté droit ou gauche de votre iPhone entre les bras.
Positionnez les ventouses près du bord inférieur de l'iPhone - une à l'avant et une à l'arrière.
Appuyez sur les ventouses pour appliquer la succion sur la zone souhaitée.
Tirez la poignée vers l'avant pour bloquer les bras.
Tournez la poignée de 360 degrés dans le sens des aiguilles d'une montre ou jusqu'à ce que les ventouses commencent à s'étirer.
Vérifiez que les ventouses restent bien alignées entre elles. Si elles commencent à se décaler, détachez-les pour les réaligner.
Posez votre iPhone sur quelque chose de solide comme un livre à couverture rigide, pour qu'il tienne tout seul à l'horizontale. Ainsi, il sera plus facile de procéder aux étapes suivantes.
Servez-vous d'un sèche-cheveux pour faire chauffer le bord inférieur de l'iPhone. L'écran doit être légèrement trop chaud au toucher.
Attendez une minute pour donner à l'adhésif le temps de se détendre et d'ouvrir un interstice.
Insérez un médiator sous le joint en plastique de l'écran, dès que l'Anti-Clamp a ouvert un interstice suffisant.
Passez les deux étapes suivantes.
Utilisez un sèche-cheveux ou un pistolet à air chaud pour chauffer le bord de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
Appliquez une ventouse en bas de l'écran, tout en évitant le rebord même.
Tirez sur la ventouse en exerçant une pression ferme et constante, pour créer un léger espace entre l'écran et le châssis.
Insérez un médiator dans l'espace sous le joint en plastique de l'écran.
Utilisez un sèche-cheveux pour chauffer le bord droit de l'iPhone (celui avec le bouton de marche) pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
Faites glisser le médiator autour du coin inférieur droit de l'iPhone afin de décoller l'adhésif.
Parcourez ensuite le bord droit de l'iPhone, jusqu'au coin supérieur droit.
Laissez le médiator dans le coin supérieur droit avant de continuer.
Utilisez un sèche-cheveux pour chauffer le bord supérieur de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
Insérez votre médiator sous le coin supérieur droit du téléphone. Faites-le glisser autour du coin supérieur droit et sur la moitié du bord supérieur, en vous arrêtant juste avant l'encoche du haut-parleur interne.
Utilisez un sèche-cheveux pour chauffer le bord gauche de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
You will need to replace the entire module connected via the damaged ribbon cable, or worse, buying an entirely new screen.
Insérez un second médiator dans le coin inférieur gauche de l'iPhone.
Faites pivoter les deux médiators en même temps, jusqu'à ce que les clips du bord gauche se détachent.
Tournez votre iPhone de façon que son bord droit est en face de vous.
Ouvrez votre iPhone en faisant pivoter le bord droit de l'écran vers le haut, comme la couverture d'un livre.
Appuyez l'écran contre un objet pour le maintenir en hauteur lorsque vous travaillez sur le téléphone.
Utilisez un tournevis Y000 pour retirer les huit vis qui fixent le cache du connecteur de la batterie :
Six vis de 1,3 mm de long
Une vis de 1,6 mm de long
Une vis de 1,9 mm de long
You need to correct the guide. Are five 1.3mm-long screws two 1.6mm-long screws and one 1.9mm-long screw.
second 1.6mm-long screw sit a third one counting from left on right side of lcd flex cable
There is a second 1.6 mm-long screw that is placed on the lower standoff screw. The top left (third total from left) is slightly longer to accommodate the standoff screw. Placing this in the wrong spot will cause long screw damage.
The two previous commenters are correct, probably change to notate the two 1.6mm screws.
Nice job, guys!
Outil utilisé dans cette étape :Tweezers$4.99
Saisissez le cache du connecteur avec une pincette et faites-le glisser vers le bas pour dégager les nappes.
Retirez le cache du connecteur.
Débranchez la nappe de la batterie de sa prise, en soulevant le connecteur à la verticale avec l'extrémité pointue d'une spatule (spudger).
Repliez légèrement le connecteur pour l'éloigner de la carte mère, afin d'éviter qu'il n'entre accidentellement en contact avec sa prise et qu'il n'alimente le téléphone pendant la réparation.
Débranchez la première nappe de l'écran de sa prise, en soulevant le connecteur à la verticale avec l'extrémité pointue d'une spatule.
Utilisez un tournevis Y000 pour retirer les cinq vis qui fixent le cache de l'ensemble caméra arrière :
Quatre vis Y000 d'une longueur de 1,5 mm
Une vis Y000 d'une longueur de 1,2 mm
Utilisez un tournevis cruciforme pour retirer la vis d'une longueur de 1,7 mm.
Saisissez le cache de l'ensemble caméra arrière à l'aide d'une pincette.
Déplacez le cache vers les boutons de volume pour libérer le petit bord métallique du châssis.
Retirez le cache de l'ensemble caméra arrière.
Utilisez une spatule pour déconnecter la nappe de la caméra ultra grand-angle et du téléobjectif, en faisant levier sur le connecteur pour le soulever tout droit hors de sa prise.
Utilisez une spatule pour déconnecter la nappe de la caméra ultra grand-angle, en faisant levier sur le connecteur pour le soulever tout droit hors de sa prise.
Insérez la pointe d'une spatule sous le bord inférieur de l'ensemble caméra arrière.
Pivotez la spatule vers le bas pour soulever l'ensemble caméra arrière.
Ôtez l'ensemble caméra arrière à l'aide d'une pincette ou de vos doigts.
Si possible, allumez votre appareil et testez votre réparation avant d'installer un nouvel adhésif et de refermer.
Comparez votre pièce de remplacement à la pièce d'origine. Il vous faudra peut-être transférer d'éventuels composants restants ou retirer des films adhésifs de la nouvelle pièce avant de commencer le remontage.
Pour remonter votre appareil, suivez ces instructions en sens inverse.
Déposez vos déchets électroniques dans un point de recyclage certifié.
Votre réparation iPhone 14 Pro Max ne s’est pas déroulée comme prévu ? Consultez nos conseils basiques de diagnostic ou notre Forum pour obtenir de l’aide.
7 autres ont terminé cette réparation.
Merci à ces traducteurs :
87%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
Excellent guide, thank you very much! It was very easy to follow
Can someone verify whether there is any feature loss replacing the cameras?
