Google Pixel Watch Screen Replacement
Introduction
Passez à l'étape 1Use this guide to replace a cracked, broken, or dead screen on your Google Pixel Watch.
Note: Gaining access to the screen cable requires removing the battery. If the battery gets even slightly deformed during removal, it's a potential fire hazard and must be replaced.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to to reattach the screen when reassembling the device.
Retaining water resistance after the repair will depend on how precisely the adhesive is reapplied, but your device will lose its IP (Ingress Protection) rating.
Note: This guide was written using a GBZ4S LTE model. If you have the non-LTE version, you can still use this guide—but there might be slight visual discrepancies.
Remove the watch band by pressing the band release button and sliding the band over the button while pulling it away from the watch.
Repeat for the other watch band.
Heat an iOpener and apply it to the screen for about two minutes to soften the adhesive securing the screen.
Outil utilisé dans cette étape :iFlex Opening Tool$11.99
Insert an iFlex into the thin gap between the screen and frame, left of the digital crown.
Slide the iFlex around the entire perimeter of the watch to slice all of the screen adhesive.
Remove the iFlex and reinsert it under the screen, to the right of the speaker grille.
Twist the iFlex to pry the screen up.
Outil utilisé dans cette étape :FixMat$36.95
Use a Torx T2 screwdriver to remove the 2.1 mm-long screw securing the speaker bracket.
Outil utilisé dans cette étape :Tweezers$4.99
Use a pair of tweezers to remove the speaker bracket.
Use the point of a spudger to pry up and disconnect the vibration motor‘s press connector.
Use tweezers to peel up the yellow tape securing the vibration motor cable to the battery.
Use a Torx T2 screwdriver to remove the two screws securing the vibration motor:
One 1.8 mm-long screw
One 2.8 mm-long screw
Use tweezers to lift the grounding bracket out of its recess and remove it.
Use a Torx T2 screwdriver to remove the two 3 mm-long screws securing the battery bracket.
Use tweezers to peel up the yellow tape from the edge of the battery, next to the speaker.
Slide the flat end of a spudger under the edge of the battery where the vibration motor was.
Pry up the battery until you can grip it with your fingers.
Carefully place the battery next to the watch to access the battery connector bracket.
Use a Torx T2 screwdriver to remove the two 1.5 mm-long screws securing the battery connector bracket.
Use tweezers to remove the battery connector bracket.
Use the point of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Note: The screen assembly cable is threaded underneath the test port cable.
Use the point of a spudger to disconnect the screen assembly cable by carefully prying the connector straight up from its socket.
Slide the flat end of a spudger underneath the screen assembly cable to loosen its adhesive and detach it from the watch frame.
Carefully pull the screen assembly cable out from underneath the test port cable.
Remove the screen assembly.
If you were installing a new batter—For optimal performance, calibrate your newly installed battery after completing this guide.
4 autres ont terminé cette réparation.
7 commentaires de tutoriel
Bekommt man das Display überhaupt irgendwo zu kaufen? Ich habs nicht irgendwo gefunden
Whee do you get the screen
Replacement screen can be obtained by buying a broken Pixel Watch (with an intact screen) off eBay. There aren't a lot for sale but they do come up. I just bought one for 34 USD plus 15 USD shipping to Canada.
What width replacement adhesive is needed? Is this Tesa tape suitable? Tesa 61395 Tape
Is it an adhesive tape or will something like uhu or evostik work?
Gibt es ein schon fertiges Klebeband für das Display?
