HP EliteBook 845 G9 Wi-Fi Module Replacement
Introduction
Passez à l'étape 1Use this guide to replace the WLAN module (aka Wi‑Fi card) in your HP EliteBook 845 G9 laptop.
You may need to replace the WLAN module if your laptop frequently drops Wi‑Fi connections or experiences unusually slow speeds despite a strong signal. Depending on your laptop configuration, you may be able to upgrade your WLAN card to one with newer Wi-Fi standards, if necessary.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
Ce dont vous avez besoin
Outils
Afficher plus…
Étape 1 Before you begin
Attention : l'étape 1 est issue d'un tutoriel marqué comme en cours.
Save your work, fully shut down your laptop, and unplug all cables.
Use a Phillips screwdriver to fully loosen (not remove) the five captive screws securing the bottom cover.
Position your laptop so the rear edge (with the screen hinge) is closest to you.
Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
Use your spudger to pry up the cover to release the clip securing it.
Leave the spudger inserted under the bottom cover for the next step.
Slide the cover towards the screen hinge to disengage the clips on the opposite edge.
Lift and remove the cover.
Étape 7 Disconnect the battery
Attention : l'étape 7 est issue d'un tutoriel marqué comme en cours.
Position your laptop so the front edge (opposite the screen hinges) is closest to you.
Use the point of a spudger to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
Étape 8 Disconnect the WLAN module cables
Attention : l'étape 8 est issue d'un tutoriel marqué comme en cours.
Slide an arm of a pair of angled tweezers under the metal neck of one of the coaxial connectors on the WLAN (Wi-Fi) module, near the right hinge.
Lift straight up to disconnect the cable.
Repeat the process to disconnect the remaining coaxial connector.
Use tweezers to hold a connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again. Don't use excessive force.
Use a Phillips screwdriver to remove the 2.5 mm‑long screw securing the Wi-Fi module.
Grip the Wi-Fi module by its edges and pull it straight out of its socket to remove it.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
