Aller au contenu principal
Heyday Wireless Speaker 8125 Speaker Replacement
Ryan Butler
Ryan Butler et 5 autres contributeurs
Dernière mise à jour le May 7, 2024
10 - 35 minutes
Difficile
Is the sound quality of your Heyday Wireless Speaker 8125 no longer as good as it once was? It might be time to replace the speaker. Following the steps in this guide will help you replace the speaker on your Heyday Wireless Speaker 8125 (model number BTSP47).
Before following this guide, please refer to this device's troubleshooting page where speaker and audio related symptoms are present.
Prior to beginning this repair, be sure to turn off the device and unplug from the charger.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Heyday Wireless Speaker 8125 Speaker Replacement, Grille: étape 1, image 1 de 3 Heyday Wireless Speaker 8125 Speaker Replacement, Grille: étape 1, image 2 de 3 Heyday Wireless Speaker 8125 Speaker Replacement, Grille: étape 1, image 3 de 3
    • Orient the speaker so that it is sitting upright.
    • Use your nondominant hand to hold the speaker in place while you firmly push the plastic spudger into the seam between the device wall and the grille.
    • Push down with the plastic spudger and lift the grill until you feel it separate from the speaker.
    • Gently remove it from the top of the device.
  2. Heyday Wireless Speaker 8125 Speaker Replacement, Black Plastic Cover: étape 2, image 1 de 2 Heyday Wireless Speaker 8125 Speaker Replacement, Black Plastic Cover: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to remove the four black rubber screw covers.
    • Use a Phillips screwdriver to remove four 8.9 mm screws underneath the screw covers.
    • Once all four screws are out, gently pull the black cover out using your hands or use a spudger to pry it out.
    • The cover is attached to the motherboard beneath by the speaker cable. Don't yank the cover from the device. You will need to detach the connector from the socket before removing it entirely.
  3. Heyday Wireless Speaker 8125 Speaker Replacement, Speaker: étape 3, image 1 de 2 Heyday Wireless Speaker 8125 Speaker Replacement, Speaker: étape 3, image 2 de 2
    • This next step requires the use of a heat gun or hair dryer. Follow this guide for more information on using a heat gun.
    • Use a heat gun on low, around the edges of the speaker to loosen the adhesive that holds the speaker in place.
    • Point it down on the speaker at a distance of about 2-4 inches while moving in a circular motion around the edges of the speaker. Do this for about 30 seconds.
    • Use caution when using a heat gun. The barrel of a heat gun gets very hot. If used incorrectly, you could burn yourself or possibly even damage the device.
    • Turn off the heat gun and set it aside.
    • Use an opening tool or plastic spudger in between the edges of the speaker and the black case. Gently work the spudger around the perimeter of the speaker until it is free from the cover.
    • Once the speaker is loose, gently pull the speaker out.
    • Don't yank it out. The speaker is attached by a cable to the motherboard.
  4. Heyday Wireless Speaker 8125 Speaker Replacement: étape 4, image 1 de 2 Heyday Wireless Speaker 8125 Speaker Replacement: étape 4, image 2 de 2
    • Use tweezers or a spudger to disconnect the speaker cable from the socket on the motherboard.
Ryan Butler
Membre depuis le 01/18/23
363 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 248
