Aller au contenu principal
How to Open a Google Pixel Watch
Dominik Schnabelrauch
Dominik Schnabelrauch et un autre contributeur
Dernière mise à jour le June 23, 2024
15 - 30 minutes
Modérée
Use this guide to open your Google Pixel Watch for repairs.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach the screen when reassembling the device.
Retaining water resistance after the repair will depend on how precisely the adhesive is reapplied, but your device will lose its IP (Ingress Protection) rating.
Note: This guide was written using a GBZ4S LTE model. If you have the non-LTE version, you can still use this guide—but there might be slight visual discrepancies.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. How to Open a Google Pixel Watch, Remove the watch band: étape 1, image 1 de 3 How to Open a Google Pixel Watch, Remove the watch band: étape 1, image 2 de 3 How to Open a Google Pixel Watch, Remove the watch band: étape 1, image 3 de 3
    • Before starting repairs, turn off your watch and take it off the charger.
    • Remove the watch band by pressing the band release button and sliding the band over the button while pulling it away from the watch.
    • Repeat for the other watch band.
  2. How to Open a Google Pixel Watch, Loosen the screen adhesive: étape 2, image 1 de 1
    • Heat an iOpener and apply it to the screen for about two minutes to soften the adhesive securing the screen.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  3. How to Open a Google Pixel Watch, Insert an iFlex: étape 3, image 1 de 2 How to Open a Google Pixel Watch, Insert an iFlex: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    iFlex Opening Tool
    $11.99
    • The thin seam between the frame and screen requires a thin metal tool—take your time and work carefully to avoid scraping or gouging the watch body or glass.
    • Insert an iFlex into the thin gap between the screen and frame, left of the digital crown.
  4. How to Open a Google Pixel Watch, Slice the screen adhesive: étape 4, image 1 de 3 How to Open a Google Pixel Watch, Slice the screen adhesive: étape 4, image 2 de 3 How to Open a Google Pixel Watch, Slice the screen adhesive: étape 4, image 3 de 3
    • When slicing the screen adhesive, insert the iFlex no deeper than 3 mm to prevent damaging internal components.
    • Slide the iFlex around the entire perimeter of the watch to slice all of the screen adhesive.
  5. How to Open a Google Pixel Watch, Pry up the screen: étape 5, image 1 de 2 How to Open a Google Pixel Watch, Pry up the screen: étape 5, image 2 de 2
    • Remove the iFlex and reinsert it under the screen, to the right of the speaker grille.
    • Twist the iFlex to pry the screen up.
    • Don't try to fully remove the screen just yet, as it‘s still connected to the watch assembly by a delicate cable.
  6. How to Open a Google Pixel Watch, Swing open the screen: étape 6, image 1 de 3 How to Open a Google Pixel Watch, Swing open the screen: étape 6, image 2 de 3 How to Open a Google Pixel Watch, Swing open the screen: étape 6, image 3 de 3
    • Be careful not to strain the screen assembly cable when you open the display.
    • Swing the screen open to an upright position.
    • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
2 autres ont terminé cette réparation.
Membre depuis le 11/23/16
230 827 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 648 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 20
30 derniers jours : 135
Total : 2,668
