Aller au contenu principal
Lenovo ThinkPad T480s LCD Assembly Replacement
Sarah Westberg
Sarah Westberg
Dernière mise à jour le May 4, 2025
40 minutes - 1 heure
Modérée
Use this guide to replace the display assembly of yourLenovo ThinkPad T480s laptop.
The display assembly includes the screen bezel, hinges, camera/microphone module, WLAN and WWAN antennas, and the LCD (liquid-crystal display) screen. You may opt to replace the entire display assembly, rather than its individual components to save time. Some common symptoms of a faulty display assembly include a blank, black, or flickering screen, hinges that are stiff, loose, or dislocated, or webcam issues that cannot be resolved by fixing the laptop’s settings.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Ce dont vous avez besoin
Outils
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Afficher plus…
  1. Lenovo ThinkPad T480s LCD Assembly Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo ThinkPad T480s LCD Assembly Replacement, Bottom Cover: étape 1, image 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s LCD Assembly Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 2, image 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s LCD Assembly Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 3, image 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s LCD Assembly Replacement, LCD Assembly: étape 4, image 1 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement, LCD Assembly: étape 4, image 2 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement, LCD Assembly: étape 4, image 3 de 3
    • Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
    • When reassembling the Wi-Fi card, reattach the black wire closest to the screw and the gray wire on the other side of the black wire. With the WWAN card, reattach the blue wire on the left and the orange wire on the right.
    • There are also small color coded arrows on each card that match the corresponding wires, to make sure you connect to the correct spot.
  5. Lenovo ThinkPad T480s LCD Assembly Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 5, image 3 de 3
    • Use the spudger to disconnect the LCD cable from the motherboard.
  6. Lenovo ThinkPad T480s LCD Assembly Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 6, image 3 de 3
    • Disconnect the camera cable from the motherboard using a spudger.
  7. Lenovo ThinkPad T480s LCD Assembly Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 7, image 2 de 2
    • Remove all antenna cables from their routing.
  8. Lenovo ThinkPad T480s LCD Assembly Replacement: étape 8, image 1 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 8, image 2 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 8, image 3 de 3
    • Using the Phillips #1 screwdriver, remove three 5 mm screws from the left hinge and three 5 mm screws from the right hinge.
  9. Lenovo ThinkPad T480s LCD Assembly Replacement: étape 9, image 1 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 9, image 2 de 3 Lenovo ThinkPad T480s LCD Assembly Replacement: étape 9, image 3 de 3
    • Carefully rotate the hinges upward and remove the bottom of the machine from the LCD unit.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Sarah Westberg
Membre depuis le 03/11/19
30 283 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
120 membres
20 074 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 30
Total : 814
