Aller au contenu principal
Lenovo ThinkPad T480s LCD Panel Replacement
Sarah Westberg
Sarah Westberg
Dernière mise à jour le October 11, 2021
1 - 2 heures
Modérée
Use this guide to replace the display panel on your Lenovo ThinkPad T480s laptop.
The display panel, also known as a screen, is the component that outputs visual information from a computer.
Some signs your display panel may be faulty include a blank or black screen, flickering, no backlight, or horizontal or vertical lines. A display panel replacement may be needed if it is cracked or physically damaged. Before attempting a display panel replacement, you may be able to resolve the issue using Lenovo’s troubleshooting guide.
Before replacing your display panel, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
Ce dont vous avez besoin
Outils
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Afficher plus…
  1. Lenovo ThinkPad T480s LCD Panel Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo ThinkPad T480s LCD Panel Replacement, Bottom Cover: étape 1, image 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
    Somehow I find the screws for the T480s bottom cover to be slightly more prone to stripping, compared to the ThinkPad T480 and X1 Carbon Gen 6. However, the #1 Phillips screws on the T480s have drives that are cut in a way that also let you use a #3 flathead.
    Tai Lam - Réponse
  2. Lenovo ThinkPad T480s LCD Panel Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 2, image 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s LCD Panel Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s LCD Panel Replacement: étape 3, image 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: étape 4, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: étape 4, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: étape 4, image 3 de 3
    • Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
    • When reassembling the Wi-Fi card, reattach the black wire closest to the screw and the gray wire on the other side of the black wire. With the WWAN card, reattach the blue wire on the left and the orange wire on the right.
    • There are also small color coded arrows on each card that match the corresponding wires, to make sure you connect to the correct spot.
  5. Lenovo ThinkPad T480s LCD Panel Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 5, image 3 de 3
    • Use the spudger to disconnect the LCD cable from the motherboard.
  6. Lenovo ThinkPad T480s LCD Panel Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 6, image 3 de 3
    • Disconnect the camera cable from the motherboard using a spudger.
  7. Lenovo ThinkPad T480s LCD Panel Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T480s LCD Panel Replacement: étape 7, image 2 de 2
    • Remove all antenna cables from their routing.
  8. Lenovo ThinkPad T480s LCD Panel Replacement: étape 8, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 8, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 8, image 3 de 3
    • Using the Phillips #1 screwdriver, remove three 5 mm screws from the left hinge and three 5 mm screws from the right hinge.
  9. Lenovo ThinkPad T480s LCD Panel Replacement: étape 9, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 9, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 9, image 3 de 3
    • Carefully rotate the hinges upward and remove the bottom of the machine from the LCD unit.
  10. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: étape 10, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: étape 10, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: étape 10, image 3 de 3
    • Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
    • It is attached by adhesive so be careful not to break it. You may hear loud snaps when detaching the clips; this is normal.
  11. Lenovo ThinkPad T480s LCD Panel Replacement: étape 11, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 11, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 11, image 3 de 3
    • Use the spudger to remove the internal bezel.
    • Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
    • Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
    • You will feel resistance and hear snapping as you remove the bezel because it is connected with clips. Be careful that you don't crack the bezel. The plastic is delicate in places.
  12. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Panel: étape 12, image 1 de 2 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Panel: étape 12, image 2 de 2
    • Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
  13. Lenovo ThinkPad T480s LCD Panel Replacement: étape 13, image 1 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 13, image 2 de 3 Lenovo ThinkPad T480s LCD Panel Replacement: étape 13, image 3 de 3
    • Gently lift the panel and flip it over.
    • The panel is still connected to the unit by the LCD cable so be careful not to rip the connector when flipping it over.
  14. Lenovo ThinkPad T480s LCD Panel Replacement: étape 14, image 1 de 2 Lenovo ThinkPad T480s LCD Panel Replacement: étape 14, image 2 de 2
    • Peel back the tape covering the LCD cable connector.
    • Use the spudger to unlock the LCD cable.
  15. Lenovo ThinkPad T480s LCD Panel Replacement: étape 15, image 1 de 2 Lenovo ThinkPad T480s LCD Panel Replacement: étape 15, image 2 de 2
    • Remove the LCD cable from the socket.
  16. Lenovo ThinkPad T480s LCD Panel Replacement: étape 16, image 1 de 2 Lenovo ThinkPad T480s LCD Panel Replacement: étape 16, image 2 de 2
    • Remove the LCD panel from the system.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 autres ont terminé cette réparation.
Sarah Westberg
Membre depuis le 03/11/19
30 085 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 857 tutoriels rédigés
4 commentaires de tutoriel
Hello, just wondering about step 4.
The description does not match what the image is showing for the Wi-Fi card wiring. The image is showing the black wire being closest to the screw (bottom) and the grey wire being on the opposite side (top). The description describes the opposite which is correct. The correct wiring can be seen in step 3 when the lid has been opened.
Kromagnon - Réponse
Hi Kromagnon, thanks for pointing this out! I believe when I opened up the device, (which was likely used ), the Wi-Fi card cables were inadvertently switched (as shown in Step 3). I wrote my instructions based on how they were initially connected, but when reassembling I put the cables back correctly and missed the fact that the instructions were inconsistent. Step 4 is now correct. Thanks again!
Sarah Westberg -
Why even remove the Wifi cables? Do they actually get in the way of the replacement? I have done this before and don't think that they do.
Nathan Morris - Réponse
Hi Nathan, thanks for your question. It looks like the Wi-Fi cables are connected to the display assembly, so they will need to be disconnected from the Wi-Fi card prior to removing the display.
Sarah Westberg -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 23
30 derniers jours : 110
Total : 7,283
