Aller au contenu principal
Lenovo ThinkPad T480s SSD Replacement
Sarah Westberg
Sarah Westberg et un autre contributeur
Dernière mise à jour le April 20, 2025
10 - 20 minutes
Modérée
Use this guide to replace the SSD in your Lenovo ThinkPad T480s laptop.
An SSD (short for “solid-state drive”) is a storage component in a computer. SSDs use flash memory, as opposed to the spinning disks and moveable parts used in an HDD (hard disk drive). As a result, SSDs are much quieter and operate more quickly than HDDs. Signs your SSD may be faulty include corrupted data, read-only errors, frequent crashes, or blue screen of death.
If you are able to recover any data saved to your SSD, be sure to back up your files before beginning this guide. Also, make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad T480s SSD Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo ThinkPad T480s SSD Replacement, Bottom Cover: étape 1, image 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s SSD Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 2, image 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s SSD Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s SSD Replacement: étape 3, image 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s SSD Replacement, Battery: étape 4, image 1 de 2 Lenovo ThinkPad T480s SSD Replacement, Battery: étape 4, image 2 de 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s SSD Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 5, image 3 de 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s SSD Replacement, SSD: étape 6, image 1 de 2 Lenovo ThinkPad T480s SSD Replacement, SSD: étape 6, image 2 de 2
    • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
  7. Lenovo ThinkPad T480s SSD Replacement: étape 7, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 7, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 7, image 3 de 3
    • Pull the SSD out of the socket.
Sarah Westberg
Membre depuis le 03/11/19
29 908 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 768 tutoriels rédigés
2 commentaires de tutoriel
Is there a need to remove the battery?
Sanjay - Réponse
Hi Sanjay, we just want to make sure that there is no power to the system and the step to remove the battery is included as a precaution. Typically, you could detach the connector from the motherboard without removing the battery, and that would be sufficient. This connector is integrated into the battery case so we recommend battery removal. Thanks!
Sarah Westberg -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 96
Total : 3,448
