Lenovo V14-IIL Display Assembly Replacement
Ce dont vous avez besoin
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
