Aller au contenu principal
Remplacement du ventilateur du MacBook Unibody modèles A1342
Walter Galan
Walter Galan et 6 autres contributeurs
Dernière mise à jour le January 19, 2024
10 - 30 minutes
Modérée
Remplacer un ventilateur défectueux évitera que votre ordinateur surchauffe.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Remplacement du ventilateur du MacBook Unibody modèles A1342, Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les huit vis Phillips 4 mm par lesquelles le boîtier inférieur est fixé au MacBook.
    According to this page http://support.apple.com/kb/HT1651?viewl..., the 8 screws are not identical.
    Can anybody tell me where each kind of screw is supposed to go?
    Gregoire - Réponse
    They are all 100% Identical. You were probably looking at a different model, or Apple has entered the wrong information... Hey, It happens...
    Owen Davies -
    The screws on the Late 2009 are identical. The blue lock compound might make tightening some require a little more effort.
    svenaustx - Réponse
    Can I replace it with a SATA 3 cable?
    nm - Réponse
    A1342 macbook does not have the right controller to support sata III
    Owen Davies -
    hi, i just got back from the apple store and they are really keen for me to upgrade to a new laptop since my battery is old and the screen is cracked, so glad i found ifixit i would love to upgrade this puppy! gonna make it a real sleeper! styler hall wrote about sticking 16 gb of ram in his a 1342 ? is this a simply mather of ordering 3 4gb sticks ?aslo i currently have 4 gb and would like to upgrade to 8 ( or indeed 16) does that mean i need to buy all new sticks or can i continue to use the old one and stick a new one next to it ?
    thanks again mick van aar, perth western aus.
    michelvanaar - Réponse
    The A1342 will take up to 16 GB of RAM, however, there are only two RAM slots, so use two 8-GB RAM modules. Other World Computing (OWC) is a great reference source for info on exactly which RAM to use with which model; prices are usually much better on EBay though. Add an SSD from OWC and your machine will really scream!
    I hope that helps!
    gdesbrisay -
    Gregoire is right. The 8 screws are absolutely NOT identical, I’m looking at them right now, weeowey weeowey.
    John Guzman - Réponse
    I just wanted to say that, in 2020, i used these instructions to replace the magsafe socket on my A1286, mid-2012, pre-Retina MacBook Pro. The internal layout is not quite the same but close enough for me to do the job. I skipped the steps of fully disconnecting the fans and speakers because of what others had said about breaking the sockets. it just meant I had to be extremely careful when lifting up the main board so that I did not tear and break the connections. I was able to disconnect the old magsafe socket with the board flat and in situ, but there was no where near enough room to be able to aline and press home the new par home. Reluctantly i had to lever up the board. This was difficult as there is a tapped post that holds a screw in the way close to where the USB sockets are, that prevented the board lifting up and out. I had to be quite forceful to manouevre the sockets out from the edge of the case.
    Paul Burridge - Réponse
  2. Remplacement du ventilateur du MacBook Unibody modèles A1342: étape 2, image 1 de 3 Remplacement du ventilateur du MacBook Unibody modèles A1342: étape 2, image 2 de 3 Remplacement du ventilateur du MacBook Unibody modèles A1342: étape 2, image 3 de 3
    • Le boîtier inférieur est construit en aluminium avec un revêtement en caoutchouc. Ne pliez pas trop l'aluminium lors du retrait, car une déformation permanente générerait des problèmes de tolérance après le remontage.
    • Soulevez légèrement le boîtier arrière au niveau de la fente.
    • Continuez à faire courir vos doigts entre les boîtiers inférieur et supérieur jusqu'à ce que le boîtier supérieur se dégage des clips de fixation.
    • La position de ces trois clips est indiquée dans la troisième photographie.
    Do the retaining clips have to be re-engaged when replacing the lower case?
    John Morley - Réponse
    Answering my own question, the clips re-engage when the lower case is correctly positioned. You can help them by gently pressing the lower case with your thumbs midway along the two short sides. When everything is correctly aligned the eight screw holes line up.
    John Morley -
    Rather than running your fingernail down the sides to free up the retaining clips, I found that using an old credit card, inserted about 1/4”, to run along the left and right side popped those end retaining clips right off with no problem. You may need to twist the card slightly when in the middle area to help pop those off.
    bdahl385 - Réponse
  3. Remplacement du ventilateur du MacBook Unibody modèles A1342, Batterie: étape 3, image 1 de 1
    • Pour des raisons de précaution, nous conseillons de déconnecter le connecteur de la batterie de la carte mère pour éviter une décharge électrique. Cette étape est facultative et non obligatoire.
    • Avec l'extrémité plate d'une spatule (spudger), soulevez le connecteur de la batterie de sa prise sur la carte mère.
    • Il est peut-être plus facile de soulever les deux côtés du connecteur avec vos ongles.
    you do not need to remove the battery when replacing the hard drive or ram
    brilldoctor - Réponse
    beware not to lift the connector to close of the angle, as the picture suggest it. It might broke the angle. Attack by the middle.
    naamol - Réponse
    Not necessary?
    hikkymemo - Réponse
    Be careful of the corner of the battery cable connector when trying to pry it off with the spudge. I knocked the corner of mine. No operational impact but was not very pleasing!
    jljordanweb - Réponse
    Not necessary, but a good idea, so as to avoid any spurious charges going through the boards...
    svenaustx - Réponse
    @Svenaustx - What could happen if not removing this battery? Worst case? Not a geek on this but did change RAM on my Macbook Pro "15. Can't remember disconneting the battery back then. Shouldn't it be sufficient shutting the Mac off and ensure it has been used for an hour or so before replacing RAM?
    Allan Clarke -
    i used a metal pry and noticed some sparking when i disconnected the battery. replaced ram. now it wont turn on. did i fry it?
    Ian Lynch - Réponse
  4. Remplacement du ventilateur du MacBook Unibody modèles A1342, Ventilateur: étape 4, image 1 de 1
    • Avec une spatule (spudger), soulevez le connecteur de la nappe AirPort/Bluetooth pour la déconnecter le la carte mère.
    • Repliez délicatement la nappe AirPort/Bluetooth pour dégager le ventilateur.
  5. Remplacement du ventilateur du MacBook Unibody modèles A1342: étape 5, image 1 de 3 Remplacement du ventilateur du MacBook Unibody modèles A1342: étape 5, image 2 de 3 Remplacement du ventilateur du MacBook Unibody modèles A1342: étape 5, image 3 de 3
    • Avec l'extrémité plate d'une spatule (spudger), soulevez délicatement le connecteur du ventilateur pour le débrancher de la carte mère.
    • Il est utile de faire pivoter la spatule en dessous des câbles du ventilateur pour débrancher le connecteur.
    • La prise et le connecteur du ventilateur sont montrés sur la deuxième et troisième photo. Veillez à ne pas casser la prise en plastique du ventilateur quand vous retirez le connecteur du ventilateur de sa prise. La configuration de la carte mère de votre machine peut différer de celle de la deuxième photo mais la prise du ventilateur est la même.
    I think I broke it off the board. Is this fixable?
    Javi Montt Sanchez - Réponse
    I broke the socket off the logic board, but it is fixable. I succesfully welded it back but it's a very tricky thing to do, even with the right tools, the socket is plastic made so it melt easily and you need very good eyes because soldering iron and magnifying glass are very annoying to use together. If you are not confident to do the right thing, dont do it ! Check your entourage, maybe you have electronic buffs who could do it right...
    arthur - Réponse
  6. Remplacement du ventilateur du MacBook Unibody modèles A1342: étape 6, image 1 de 1
    • Dévissez les trois vis suivantes, fixant le ventilateur au boîtier supérieur :
    • Une vis cruciforme de 7,1 mm
    • Deux vis cruciformes de 5,3 mm
    The two 5.3 mm Phillips screws are so tight, that I can’t open them. I’ve tried to apply some oil with an Q-Tip. Has someone an other clue?
    David Bach - Réponse
    Take a look at this guide for removing stripped screws, How to Remove a Stripped Screw, and see if any of these options might work for your particular screw.
    David Bach -
  7. Remplacement du ventilateur du MacBook Unibody modèles A1342: étape 7, image 1 de 1
    • Ôtez le ventilateur du boîtier supérieur.
    My right screw is not possible to loosen because the part where the bit should fit ist round now. The screw is tigthend so hard. What can I do?
    PitStorm - Réponse
    Take a look at this guide for removing stripped screws, Comment enlever une vis cassée, and see if any of these options might work for your particular screw.
    Ethan Lockwood -
Pour remonter votre ordinateur, suivez les instructions dans le sens inverse.
80 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
3 commentaires
Replaced the fan with an used one. After booting the fan made a very loud sound as if it was running on max speed. A SMC reset fixed the issue and the fan returned to normal speed and sound.
[deleted] - Réponse
Wish I had read Maurices comment. I did this fix because my fan had a noisy bearing. But I found the sound of the fan running at full speed after the replacement to be more annoying. So I swapped it back. didn’t think top reset the SMC.
Paul Ceccato - Réponse
Simple and concise…Thanks a whole bunch for the instructions.
Glenn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 22
Total : 44,561
