Aller au contenu principal
Samsung Gear S2 Motherboard Replacement
Jacob Baldwin
Jacob Baldwin et 3 autres contributeurs
Dernière mise à jour le October 19, 2023
10 - 15 minutes
Modérée
Have your applications or watch become unresponsive? Replacing the motherboard may fix these issues.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Samsung Gear S2 Motherboard Replacement, Watch Strap: étape 1, image 1 de 2 Samsung Gear S2 Motherboard Replacement, Watch Strap: étape 1, image 2 de 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
    The warning to turn off the watch to avoid electrical shock was a joke, right?!
    nanev - Réponse
    The screws don't seem to be turning easily. What's the best way to loosen them without stripping them?
    Mark Franz - Réponse
    I’m going to be shocked by a dead 3.8V battery? Of course, only if the watch is powered on. Ridiculous statements like this do not reflect positively on the credibility of this entire procedure. If the author seriously thinks this is a danger then I question your basic understanding of electronics.
    Alex Tatistcheff - Réponse
    … to avoid being shocked when you lose your data! :)
    Reuben Janzen-Martin - Réponse
  2. Samsung Gear S2 Motherboard Replacement: étape 2, image 1 de 2 Samsung Gear S2 Motherboard Replacement: étape 2, image 2 de 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
    The bracelet should be removed first!
    Das Armband sollte zuerst entfernt werden!
    Wilhelm Gregorius - Réponse
  3. Samsung Gear S2 Motherboard Replacement: étape 3, image 1 de 2 Samsung Gear S2 Motherboard Replacement: étape 3, image 2 de 2
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Motherboard Replacement, Back: étape 4, image 1 de 2 Samsung Gear S2 Motherboard Replacement, Back: étape 4, image 2 de 2
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
    My watch had sticky glue between the top and bottom portions of the case. I don’t think my watch will be as waterproof after this repair.
  5. Samsung Gear S2 Motherboard Replacement, Motherboard: étape 5, image 1 de 2 Samsung Gear S2 Motherboard Replacement, Motherboard: étape 5, image 2 de 2
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Motherboard Replacement: étape 6, image 1 de 3 Samsung Gear S2 Motherboard Replacement: étape 6, image 2 de 3 Samsung Gear S2 Motherboard Replacement: étape 6, image 3 de 3
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Motherboard Replacement: étape 7, image 1 de 2 Samsung Gear S2 Motherboard Replacement: étape 7, image 2 de 2
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
7 autres ont terminé cette réparation.
Jacob Baldwin
Membre depuis le 02/20/17
3 432 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G3, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 membres
23 tutoriels rédigés
6 commentaires de tutoriel
Where do you get the mother board.
Walter Meekins - Réponse
I'm looking for a new motherboard as well.
Karen -
Where do you buy a motherboard???
kiki3w - Réponse
Do you have a good source for motherboards? Hope it helps that I +30’d you!
darkfeather72 - Réponse
Ok motherboard replaced but how can I have the watch to work in normal mode and not in factory release.?
Cyan - Réponse
I damaged one of the cables. Can I but a watch for parts to replace the cable or should I just cut my loses?
Carols Daughter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 17,065
