Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Whirlpool Refrigerator Freezer Thermistor Replacement
Ce dont vous avez besoin
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: étape 2, image 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: étape 2, image 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: étape 3, image 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: étape 3, image 2 de 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: étape 4, image 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement: étape 4, image 2 de 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: étape 5, image 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: étape 5, image 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: étape 5, image 3 de 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: étape 6, image 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: étape 6, image 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: étape 6, image 3 de 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: étape 7, image 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: étape 7, image 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: étape 7, image 3 de 3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: étape 8, image 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: étape 8, image 2 de 2
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: étape 9, image 1 de 1
    • Remove the thermistor.
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: étape 10, image 1 de 1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Repair didn’t go as planned? Ask our Answers community for help.
2 autres ont terminé cette réparation.
nicO
Membre depuis le 04/14/15
15 987 Réputation
89 tutoriels rédigés
1 commentaire de tutoriel
Does anyone know the thermistor part number it’s not listed on the parts breakdown
Tony - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 27
30 derniers jours : 131
Total : 4,128
