Xbox One Front Panel Board Replacement
Introduction
Passez à l'étape 1The front panel board hosts several components: connectors for the exterior buttons, LED button lighting, Wi-Fi antenna interconnect connector, speaker connector, and IR receiver.
If your Xbox One won’t turn on at all, have a look at the Xbox One Won’t Turn On wiki before starting this repair.
Ce dont vous avez besoin
To open your Xbox, you're going to have to cut or peel up this tamper-evident tape. But don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
Use the flat end of a spudger to free the clips securing the front panel to the upper case.
Remove the front panel from the rest of the upper case.
Gently pull up on the speaker cable connector to disconnect it from the front panel board.
Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
Disconnect the hard drive SATA power and data cables from the motherboard.
Disconnect the optical drive power and SATA data cables from the motherboard.
23 autres ont terminé cette réparation.
4 commentaires de tutoriel
Hi would you know where I could get that panel from that reienforces my consol
Also my button won't work to sync a new controller what part do I get to fix that
I did all that. Put it back together, now i push my power button and it only lights up for a second then dies. The power box and source are good. What did i do wrong?
My Xbox turns on and immediately turns back off pls help
