Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
ASUS Vivobook Max X541SA-PD0703X Troubleshooting
This troubleshooting page will help you diagnose common problems with the ASUS Vivobook Max X541SA-PD0703X. Released on May 2017, identified by model number RTL8723BE
Computer will not power on
The laptop will not respond or power up.
Faulty Charger
Make sure the charger is plugged in, and the charger indicator light is on. If the light is not on when the charger is plugged in, then the charger may be faulty. The user may consider purchasing and replacing the charger.
Faulty Battery
If the laptop only powers up when the charger is plugged in, regardless of the charging time, or the laptop does not turn on at all, then the battery may be faulty. You may consider replacing the battery * Asus Vivobook Max X541SA-PD0703X Battery Replacement
Faulty Motherboard
If you notice any problems with the screen display LED lights, or experience any difficulties creating documents, then the motherboard may be faulty. Other symptoms include, having difficulties making internet searches, your computer randomly reboots, or you notice a burning smell. If any of these symptoms occur, you may replace the motherboard * Asus Vivobook Max X541SA-PD0703X Motherboard Replacement
Keyboard/Keys not responding
The keyboard keys will not respond and appear to be malfunctioning or missing.
Faulty Keyboard
If the keyboard in not working, try to press the Caps Lock key to see if the key's indicator light goes on/off. Repeat the process with the Num Lock and Scroll Lock keys. If the lights associated with each key do not turn on/off when pressing them, try restarting your laptop. If this does not work, then you should try to replace the keyboard * Asus Vivobook Max X541SA-PD0703X Keyboard Replacement
Key is stuck
When your keyboard keys are stuck, you should check to see if there is any debris under them. In order to do this, you may turn your laptop upside down and see if anything is preventing the key from being pressed and functioning normally. As an alternative approach, you can use compressed air to blow out the debris stuck under your keys. If these methods do not work, try to REMOVE THE KEY.
Missing key
If keys on the keyboard are missing, you should buy new ones and try to REPLACE THEM.
Computer will not boot
Your computer does not load, and instead displays an error message.
Hard drive error
If your laptop is making strange noises, is acting really slow or if your data and files randomly disappear your hard drive may be damaged. To be certain, restart your computer. If the hard drive is faulty, it will display a hard disk error message. You may try defragmenting your drive. In order to do this, go to the start bar, all programs, accessories, system tools and then select disk defragmenter and follow the instructions displayed on the screen. Another solution is to try cleaning the disk. Go to my computer, general, disk clean up, and then check the boxes of the files that you want to keep and then press disk clean up. If the symptoms are still present, then you may need to replace your hard drive * Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement
Touch pad is not responding
When your touch pad does not respond or the cursor does not move.
Faulty/Unresponsive Cursor
When you use your laptop and the cursor is not responding, check if your laptop is in safe mode. If not, press and hold down the FN key, which is located between the Ctrl and Alt keys on your laptop keyboard. Press the F7 key at the top of your keyboard. Then, release the FN button.
Broken Touchpad
When your touch pad does not respond, first make sure that you have not accidentally locked the touch pad. To check this, press the windows key + q, then search and select touchpad. After that, go to device setting and uncheck the disable button. If this does not work, then try reinstalling the driver and adjust the sensitivity. To reinstall the driver, select the "Start" button, type device manager and select it, select your device, and then press reinstall driver. To adjust the sensitivity, go to Control Panel and open the mouse menu, then touch-pad driver and adjust the sensitivity. If this does not work, then you should consider replacing the touch pad * Asus Vivobook Max X541SA-PD0703X Track Pad Replacement
Disk Drive is not responding
The laptop does not read CD'.
The Disc Drive will not open
If the Disk Drive is not opening when you push the button on the side or eject it, there may be something broken or stuck. You may need to replace the Disc Drive * Asus Vivobook Max X541SA-PD0703X CD drive Replacement
Laptop won't connect to WiFi or Internet
The laptop keeps disconnecting from WiFi
Laptop won't read signals
If your laptop is not connecting to WiFi when other laptops are, there may be a problem with the WiFi chip. Try replacing it * Asus Vivobook Max X541SA-PD0703X Wi - Fi Card Replacement
1 commentaire
I shut down my Asus x541na vivobook max. And on getting to my destination. I turned it on, but it won’t come up, I plugged in the charger, it’s not indicating if the charger is working, and when i tried using the charger somewhere else. It worked fine, please what could be the possible cause for this, or how do I troubleshoot it. Thanks
Paul Matthew - Réponse
