Aller au contenu principal
Table des matières
Camera won't turn on
Battery is dead
Recharge the battery using an AC adapter. If the battery is not recharging, it is broken, and you will need to purchase a new battery replacement. If you need help replacing the battery, see our Battery Installation guide.
Bad logic board
If you have charged or replaced the battery and the camera is still not turning on, the logic board may not working properly and will need to be replaced using the Motherboard Installation guide.
Camera won't save pictures
Memory card locked
Take out the memory card and make sure that it is not locked (The memory card is located under the battery). There should be a switch on the card itself.
Corrupted memory card
If the memory card is not locked and you are still unable to save pictures, it may be faulty and you will need to purchase a new card.
Stuck Shutter/Lens staying open
Sand or other particles jamming lens
Gently tap the lens or tap the padded USB cover on a hard surface to dislodge any particles. Compressed air may need to be used to blow particles out.
Not enough power
Try replacing the battery, as there may not be enough power to retract the lens. If this does not work, plug an A/V (Audio/Visual) cable into the camera, so that the LCD screen is off and there is extra power to retract the lens.
Lens is broken
If none of the previous tips worked, the lens may be dysfunctional and beyond repair. You will need to replace it using our Lens Installation guide.
Display is Dysfunctional
LCD screen is dirty
Make sure that your screen is off. Then, Using a soft cotton or microfiber cloth, and water, gently wipe down your screen.
LCD screen will not light up, or is cracked
Replace the LCD screen using our LCD Replacement guide.
Camera won't connect to Computer
Cables are not connected properly
Check to ensure that your camera is properly connected to the computer.
Camera software is not functioning properly
Try restarting the software on your computer. If it was not installed properly, you may need to uninstall and re-install the software.
The camera driver software is out of date
Visit the Canon website and download the latest driver software.
Camera won't flash
Flash is not turned on
Press the zig-zagging down arrow on the right side of the circular button pad, and then toggle between the left and right arrows to switch between flash modes.
Flash unit is damaged
You may need to replace the flash unit, or the capacitor near the flash. The bulb may also be broken and in need of replacement. The flash unit can be replaced using our Broken Flash Unit Installation guide.
Broken Shutter Button
The shutter button is the button which is pressed to take a picture. If the camera seems to be functioning properly (turns on, LCD screen lights up), but it does not take a picture when you press the shutter button, the button may be broken. You will need to replace the shutter button using our Shutter Button Installation guide.
Nick Tompkins
Membre depuis le 01/17/12
46 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-18, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 membres
12 tutoriels rédigés
4 commentaires
Exposures are milky white. Video works fine
dafnaseaheart - Réponse
How do I take apart the camera?
Alexander Duncan - Réponse
my camera is new but my screen is not lighting up its off
Aaron Shons - Réponse
auto focus not working, zoom and everything else is fine.
Lianel Soleil - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 53
Total : 4,657
