Aller au contenu principal
Repair information for blood pressure monitors (also known as sphygmomanometers).
How to fix disconnected mercury in sphygmomanometer
My sphygmomanometer suddenly has its mercury disconnected,meaning that there are like air gaps in it, which results in wrong readings, I think there is a way to fix it, but do not know how??
it's really important to me, and I almost daily need to use it. and do not want to buy another on.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
Try firmly holding the gauge section of the sphygmomanometer and gently tap it against the palm of the other hand and see if the column re unites.
Here is a link that describes three methods of re joining the mercury column in a thermometer. The principle should be the same for a sphygmomanometer.
http://novalynx.com/store/pc/Rejoining-a...
Here is a link on how to maintain a mercury sphygmomanometer, which may also be of interest to you. http://www.ebme.co.uk/articles/maintenan....
Hopefully this is of some help.
Indice 6
6 commentaires:
Do make sure you don't spill or loose any mercury!
If you do, don't touch it and make sure you collect all of it in a sealed container to be properly disposed of (Both toxic & hazardous waste).
par
My meter is quite old. Problem is its mercury is not going up. Returns from the half way
par
@Khalid Taqdees ,
Did you read how to maintain a sphygmomanometer in the link above?
You may have to carefully remove the mercury and clean the tube and also check that the cuff and valve are OK.
par
Solution of tapping worked like a charm.
par
The mercury in my apparatus spilled out since i opened after a long time. Can this be fixed? All mercury is floating on the surface any way it could be inserted back in n used or this apparatus is gone waste
par
Afficher 1 commentaire en plus
Ajouter une réponse
deep sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 21
30 derniers jours : 69
Total : 23,494
