Aller au contenu principal
Tutoriels de démontage et réparation MacBook Pro, la ligne d'ordinateurs portables conçue pour les utilisateurs professionnels. À ce jour, la gamme MacBook Pro inclut des versions 13, 14, 15, 16 et 17 pouces avec des changements majeurs définies par les designs pré-unibody (d'origine), unibody, écran Retina, Touch Bar et SOC (système sur une puce).
Replacing HDD in early 2011 MacBook Pro with SSD.
I am thinking about replacing the HDD in my 2011 early MacBook Pro with a 500 GB SSD.
When I am looking at purchasing the SSD it is noted “This drive requires a SATA III controller”. What does this mean?
Do I need to also buy a SATA III controller or does the laptop already have one? Any help would be awesome! Thank you.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
“This drive requires a SATA III controller” is telling you the drive is a fixed speed SATA III (6.0 Gb/s) drive. It will only work properly in a system which has a SATA III (6.0 Gb/s) interface.
Your laptop has the needed interface! As you can see here:
Jump to the section Storage Dimensions sections on either you’ll see the requirements. So the system can support your drive as is!
But! We do have one issue! The original drive Apple put in was a SATA II (3.0 Gb/s). The reason we worry about this is the HD SATA cable in your system now likely can’t support the higher data rate your new drive is able to pump out. You’ll need to replace the cable. Here’s a bit more Your Hard Drive Cable Is A Ticking Time Bomb
Here’s the needed cable for a 13” model: MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable and here’s the guide in putting it in Remplacement du câble du disque dur du MacBook Pro 13" Unibody début 2011
And here’s the needed cable of a 15” model: MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable and here’s the guide in putting it in Remplacement du câble du disque dur/capteur IR du MacBook Pro 15" Unibody début 2011
And yes the part I’ve listed is the 2012 version which is the better part.
So the next issue is formatting and installing a fresh copy of macOS. If your drive is still good you can use this adapter StarTech SATA to USB Cable or use a USB thumb drive which is formatted with GUID journaled file system and use this OS installer here How to upgrade to macOS Sierra Jump down to Set 4 and click on the Blue URL labeled: Download macOS Sierra. You’ll need to unpack it and then placing it on your USB drive convert it to a bootable installer following this guide: How to create a bootable macOS Sierra installer drive. The reason we need to use this OS installer is the certificate in your older one has expired and Sierra is a better OS for your system, High Sierra has issues running on SATA based systems! If you've got an old macOS install image, it will probably stop working today
I know this is a very long answer, its just once you start the process you need to follow it though to the end!
Its not as bad as it sounds! Good Luck!
Image Replace a torn or damaged cable connecting the hard drive to the logic board in your laptop.
Produit
$29.99
Image Replace a damaged or malfunctioning SATA cable connecting the hard drive to the logic board in your Unibody MacBook Pros.
Produit
$34.99
Image MacBook Pro 13" Unibody Early 2011 Câble du disque dur
Tutoriel
Difficulté :
Modérée
25 minutes - 1 hour
Image MacBook Pro 15" Unibody Early 2011 Câble du disque dur/capteur IR
Tutoriel
Difficulté :
Modérée
Indice 1
7 commentaires:
Thank you so much Dan! This is very helpful. I ordered the new drive and the new cable you recommended. I assume when I format a USB thumb drive I will have have option to format it with GUID journals file system?
par
You need to run the disk utility form a working Mac to format the USB thumb drive.
par
Thank you again Dan. What app should I use to unpack the installer?
par
@spydergs1 - Its self unpacking on a Mac system.
par
I just read that the MacBook I was using was too new to run macOS Sierra. So it won't unpack it. Thanks for your help. I need to find an old MacBook.
par
Voir 2 commentaires en plus
Ajouter une réponse
spydergs1 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 3
Total : 2,243
