Aller au contenu principal
Acer Chromebook CB3-532-C47C Keyboard Keys Replacement
Sadie Brown
Sadie Brown et un autre contributeur
Dernière mise à jour le December 29, 2021
4 - 5 minutes
Très facile
Use this guide to remove or replace the Acer Chromebook 15 CB3-532-C47C’s laptop keys.
Computer keys are used to enter information into the device, and is the main way to input text. Malfunctioning computer keys may not depress, may not type characters, or may type extra characters when pressed. Keys may also need to be removed to clean the keyboard, or as part of cleaning the entire Chromebook. For this laptop the entire keyboard cannot be removed as it is riveted into the Chromebook’s body.
Before completing this guide refer to the troubleshooting page for other possible solutions.
Power off and unplug the device before performing any replacements.
Ce dont vous avez besoin
Outils
  1. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement, Keyboard Keys: étape 1, image 1 de 1
    • Place the plastic opening tool directly underneath the key and pry upwards to remove the key.
    • Do not use too much force to avoid separating the retainer clip on the keyboard.
  2. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement: étape 2, image 1 de 1
    • Repeat with each key that needs to be removed.
    • If you are removing the keys in order to clean the keyboard, please refer to the troubleshooting guide to complete this process.
To reassemble your device, press the keys back onto the keyboard so that the figures are facing you.
Sadie Brown
Membre depuis le 10/25/21
967 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
3 membres
7 tutoriels rédigés
1 commentaire de tutoriel
1 key has different commands. D key redirects to download, E key highlights and deletes texts and replaces it with Q, number 3 key types lots of numbers, C key types lots of letters. How can I fix this and what coulf be the possible cause of this?
Ryo Heil - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 33
Total : 366
